68-72 350 Exhaust Manifold Interchangeability (RH)
Old Aug 4, 2013 | 06:03 AM
Del70's Avatar
Are the (RH) Cutlass 350 exhaust manifolds the same/ similar/interchangeable for 68-70 and 71, 72? ( I assume they are, less slight casting number location differences...) ...thanks
Old Aug 4, 2013 | 06:50 AM
Octania's Avatar
1964 thru 1976 or so all used the #3 or #4 RH manifold. 2-bolt exit is down and aft at about 45 degree angle. Interchangeable.
After that came the #5? and similar tiny castings for 307's or 260's, all these sport a 3-bolt exit flange pointing straight down.
Old Aug 5, 2013 | 04:54 AM
Del70's Avatar
what is the difference between 350 1968-72 #3 RH and a #4 RH (is it the daul exhaust?)
thanks
Old Aug 5, 2013 | 06:58 AM
thanks
Once again, Olds never made a dedicated dual exhaust manifold for the small blocks in a RWD application. All factory SBO dual exhaust cars (including W-31s) simply had a cap on the passenger side crossover hole.
Old Aug 10, 2013 | 11:00 AM
Octania's Avatar
thanks
The only difference I can discern is the 6-digit casting ID and the large "3" or "4".
Otherwise identical and interchangeable.
HouTXCutlass
Oct 4, 2010 11:54 AM
OLDSmobility
Aug 7, 2010 10:28 AM
Alocatelli
Jul 24, 2007 09:17 PM
shaks 442 clone
Jul 23, 2007 11:46 AM
Dutch
Nov 8, 2006 05:11 AM
