68 to 69 downshift switch differences
Old Aug 18, 2016 | 06:57 AM
1968_Post's Avatar
I've looked at these 2 pics and cannot see a difference in them. 1st pic is the 401882 for the 1968. Pic 2 is the 3986863 used from 1969 thru much later years. I'm not always the most observant. Am I missing something?
Old Aug 18, 2016 | 07:34 AM
442Harv's Avatar
Lot of time, parts made to fit different years has a number change. If you use the old number, and they look up the part number, may say number was superseded, to the new number.
Old Aug 18, 2016 | 08:32 AM
1968_Post's Avatar
Thanks, I should have noted that I checked GM Parts Wiki on both these numbers and there is no supersession showing on either. It's also notable that none of the aftermarket suppliers list a kickdown switch for a 1968.
Old Aug 18, 2016 | 09:24 AM
Can't tell for sure without seeing them side-by-side, but it appears that the round peg that is pushed by the accelerator pedal arm is longer on the second one. That may be a redesign to allow that same part number to be used on multiple applications.
Old Aug 18, 2016 | 01:58 PM
BlackGold's Avatar
Especially with electrical parts, the difference could be completely internal, invisible, but still make a drastic functional difference. For example, the switch inside one might be normally open, the other normally closed. (Though I doubt that's the case here.)
Old Aug 18, 2016 | 02:27 PM
1968_Post's Avatar
Good point, I guess we'll find out. Since the 1st one is for sale for $150 and I can get a new one of the 2nd type for less than a third of that, I'm gonna take a chance I can make the 2nd one work. I'll post results after I try installing...
Old Aug 18, 2016 | 02:35 PM
The TH400 (and Jetaway) kickdown requires a N.O. switch that closes at W.O.T., so that's not it. On the other hand, it COULD be a change to the internal contact material, lubricant, or something like that.
I wonder if this has anything to do with the fact that the Junkaway trans was only offered in the 1968 and early 1969 model years before being replaced by the TH350?
Old Aug 18, 2016 | 02:58 PM
1968_Post's Avatar
Not sure... Oldsmobile parts catalog list fitment on the 1st one (401882) as 1968 F-85 and 1968-1970 Toronado only
Austin Trevor White
Apr 2, 2013 12:46 PM
metalmen
Feb 4, 2013 05:26 PM
Stevec
Jun 7, 2012 01:13 PM
sammy
Jan 10, 2012 09:45 PM
Dapapadon
Feb 26, 2008 01:37 AM
