'68 442/Cutlass fender peak moldings
Has anyone done any research or have any theories on '68's having come originally with one piece '69 style moldings? Possibly a late production year change or plant variation? I see a lot of high end '68's without the two piece moldings. With neither style being reproduced (to my knowledge), at least that is not a factor in what you see 50 years later.
Any thoughts or opinions folks?
My 68 came with the two piece molding. I was unaware that that year also had the 69 style molding. My 68 did not have the molding on the left side but I found a rust free left fender that had it on it. I did replace the short cast aluminum piece.
Thanks allyolds68, that explains the variations I noticed. My '68 is a late June build, which explains why it has the 1 piece moldings, that sure looked original to the car. This also reinforces my need to get an Assembly Manual for the '68....
Appreciate the tip, thanks!
ros6872
June 1st, 2016 09:51 AM
Fixer_Upper71
August 9th, 2011 09:21 PM
