67 W30 w/power brakes?
Old Oct 3, 2012 | 11:07 PM
CLICK FOR LARGER IMAGE IN NEW WINDOW
10/2/2012 1967 OLDSMOBILE 442 W30 4 SPEED DOCUMENTED This car comes documented with the original Protect-O-Plate, the original shop order, the original window sticker, and copies of most of the titles, including the first one - The car still retains its original w30 engine - Also included is the current address and phone number for the original owner, a famous west coast racer - restored in the original color combination, and still retains most of the original interior - This car has power steering and power disc brakes - It is a rust free car with the original floor pans and trunk pan - This car has 70,000 miles and notice it still retains the original T3 headlamps - There were approximately 502 of these cars built, - One if the best documented 67 W30's for sale on the market today
Old Oct 4, 2012 | 03:38 AM
hurst68olds's Avatar
Yes, power brakes were an OPTION on '67 W-30 cars. The "no-vacuum" restriction came out later on the '68-'70 4-speed cars equipped with the 328* duration cams
Old Oct 4, 2012 | 12:14 PM
chrisneu68olds's Avatar
Question Details please...
Can you elaborate on this? Doing research on 67's for my restore. Thanks,
Old Oct 4, 2012 | 12:53 PM
Not exactly sure what '67 info you are looking for. Are you working on a 442 or a W-30?
The '66-'67 W-30s had a .474" lift, 308* duration, 82* overlap cam.
The '68-'70 manual transmission W-30s had a .475" lift, 328* duration, 108* overlap cam.
The introduction, for the '68 model year, of the "second design" W-30 high-overlap camshaft required Oldsmobile to offer it with 4-spd ONLY as the camshaft produced insufficient vacuum to properly operate the turbo 400 and/or power brakes.
anyone know the script? for degrees?
Old Oct 4, 2012 | 01:29 PM
wmachine's Avatar
Trying to remember member
Um, not exactly. '68 W30s could be had with M21 4-speeds and M40 Autos.
Old Oct 4, 2012 | 01:57 PM
Yes, the 328 cam was 4-spd ONLY.
Yes, W-30s were available auto & 4-spd.
Old Oct 4, 2012 | 03:54 PM
I was referring to the no-vacuum restriction. What does this mean?
Old Oct 4, 2012 | 04:35 PM
64Rocket's Avatar
Looks like ad for the sale of the car. Of which looks like a scam.
maybe I'm wrong, but it sure looks to good to be true.
I check on a ad for an enclosed trailer , that was a great price. But it was a scam, of which you had to send money to this web site, of which they would deliver the trailer with in a couple of days. Big scam.
That sort of looks like what this car is, but maybe it is something else.
Gene
Old Oct 4, 2012 | 05:25 PM
An engine is an air-pump (air in & air out) - here are a couple links to explain camshaft design.
http://www.freeasestudyguides.com/ca...n-overlap.html
http://www.streetracersonline.com/articles/camshafts/
http://www.jdmcars.com/tech/lift_duration.pdf
Intake engine vacuum is created when the exhaust is closed, the intake is open & the piston is on the down stroke. With the 328* camshaft the amount of time this occurs is short and does not produce sufficient vacuum to "power" accessories that are designed to run off of "engine vacuum" - therefore an OPTION ordering restriction (large duration camshaft = no vacuum = NO turbo 400 transmission/power brakes/power trunk?/vacuum A/C door controls etc.).
Old Oct 4, 2012 | 05:34 PM
AH! Ok got it now. Thanks!
Old Oct 4, 2012 | 08:24 PM
The ad is at 442.com
Old Oct 4, 2012 | 08:44 PM
The car exists, it has been at a couple of the "big name" auctions in the past few years. I don't see a price in the ad, so how or what is it too good to be true?
What I find puzzling is - there were 503+/- W-30 cars built in '67, but the same handful keep showing up for sale (been for sale long time?) or at auction.
?? this "saffron" car, black 4-spd car on eBay, "Spanish red" auto car at Corvette & Musclecars in (North?) Canton, OH ??
Old Oct 12, 2012 | 07:59 AM
Chesrown 67 OAI's Avatar
The Spanish Red car in North Canton Ohio is definitely ar "REAL" W-30 car. I have known the car for years and tried to buy it on several occassions. The current owner is an "Olds guy" -- The North Canton dealer has the car for sale on consignment.
Yes - there are many "clone" 67 W-30s out there but I havent yet seen one that hasnt been "exposed". The cloners always happen to miss some detail that eventually exposes the "fraud"!!
Old Oct 12, 2012 | 08:14 AM
Just now looked at the pix of this car for the first time since i saw this listing.
YES! This is a REAL W-30 car. I happen to personally know this car too! I was in negotiations with a former owner about 4 years ago when he had a sudden aneurism and died. This car was "living" in NC at the time. The mans widow sold it, along with a black 66 track-pak W-30 to someone who almost immediately ran it through Meacum Auction in Fla. You can probably find the Meacum Listing on its website?
I even have pix of this cars window sticker -- so I probably have more documentation of this car that the current owner does!!! I also know that someone has changed the wheels to the SS1s. The car origially came from factory with steel wheels and full-disc wheel covers ( not very attractive). I will attach a pic of it with the correct wheels. I will also attach a pic from my personal file that shows the "un-original" firewall resistor" and also the "un-original" oil fill cap. You can compare my pix with the ones in the ad and see that it is definitely the same car!!
Old Oct 12, 2012 | 08:19 AM
For what its worth --- NHRA approved and accepted the 328 cam for the 1968 W-30 with TH400. That's what Pete Kost's Holiday Olds D/SA was.
Whether the factory left any of them out in that form is debatable??
Old Oct 12, 2012 | 08:28 AM
To my knowledge, there wasnt any 67 W-30s with TH400 built with power brakes for the same lack-of-vacuum issue? I've always been told this - whether true or not? I've yet to see a window sticker showing it either? I've seen several that had been "upgraded" with PB, but never saw it on a build sheet or window sticker ---- Just sayin..... There's always something new "poppin up" and I'm still on the look-out for this one!! Maybe the "evidence" will show up someday?? Maybe Kurt (WMachine) can add some light??
Old Oct 12, 2012 | 08:34 AM
P.S. IIRC- the car reached a top bid of $45K at Meacum and did NOT meet the "reserve" .
Old Oct 12, 2012 | 10:49 AM
If you know the car - then you should know, based (if I'm reading it correctly) on the protect-o-plate "03100" accessory code, it was OPTIONED with power steering, power brakes, deluxe radio. (formerly column auto & a white vinyl top, also)
The "saffron" road test car has power brakes also.
Old Oct 12, 2012 | 11:25 AM
wmachine's Avatar
[QUOTE=hurst68olds;464152]If you know the car - then you should know, based (if I'm reading it correctly) on the protect-o-plate "03100" accessory code, it was OPTIONED with power steering, power brakes, deluxe radio.
(/QUOTE]
"Yeah, what he said...."
Dan has it covered for you Tweed. And you had the smoking gun in your hand!
Old Oct 12, 2012 | 12:21 PM
Well - there ya go ---- I never saw the POP for the Spanish Red car -- and I dont know how to read em either for that matter.
I always assumed the car had the power brakes added on and not from factory? You are correct on the car being column shift. The current owner converted it to console/floor shift! The car was already repainted with a different red when I first saw it. No vinyl top. the attached pix is how i saw it first- before the frame-off was done on it. you can see the color difference on the underside of the deck lid which is the Spanish Red.
NOTE: you can still see the Colorado front license tag on the car. When I first looked at the car in 2002 the owner had purchased it from someone in Colorado and brought it here to Ohio. For some reason I lost the pic of the trim tag that i had in my file? Ugh!
Old Oct 12, 2012 | 01:14 PM
Here's a W30 NOT! that's for sale in Hershey this weekend - AFAIK not even a 442
I've seen "2X" often refered to simply as "floor shift automatic", but isn't it more specifically "floor shift Jetaway"?
Old Oct 12, 2012 | 07:21 PM
wmachine's Avatar
Yeah, I'd call that "way not!". Yikes! "No expense spared", no sense used.
Right, not even a 442. Framingham '67s have the same accessory codes as Lansing. And as far as I can tell, the X is for the Jetaway. The floor shift Turbo 400s have "just" a G (without the X).
Old Oct 12, 2012 | 09:13 PM
Run to Rund's Avatar
All the 67 W30 factory cars were built in Lansing.
The Dec 67 parts book shows 397328 (308 deg) for 66-68 W30s but later parts books show all 68-69 W30s had 402569 (328 deg) cam.
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
Uly49
Oct 20, 2009 07:11 PM
Gtimmons
Cars Wanted
Sep 30, 2006 06:34 PM
