'67 Toro fan motor
Old Jan 13, 2011 | 10:36 AM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
'67 Toro fan motor
Fan motor went out on my '67 Toronado, have power to the fan ....made a big schreech and then nothing...so..... what is the easiest way to get it out ? can I cut an opening in the fender well ?......question # 2 ............what motor will fit as a replacememnt ? Or what motor can I make fit ?.......thanks.................P S > as my shop is full, I will be doing this outside and , yes , it's very cold !
Old Jan 13, 2011 | 01:18 PM
knighthawk's Avatar
never mind....NAPA has a motor , in stock , and just going to cut the inner fender, woory about patching it later
Old Jan 13, 2011 | 04:19 PM
jag1886's Avatar
I worked it a radiator shop when I was in high school and we always cut the inner fender to install those. The secret was to cut it on only 3 sides and fold the flap down then you could just push it back up and tack it in place with a couple of sheet metal screws in the corners and silicone the cuts shut.
Old Jan 13, 2011 | 05:11 PM
ozoneblue's Avatar
There are actually 4 divots on the fender well if you can get it clean enough to see them use die grinder to cut 2 sides & bottom making it easier to re seal . I have had customers request to pull inner fender Or front clip I Charge by the hour& broken bolts & Blood
Old Jan 14, 2011 | 09:13 AM
knighthawk's Avatar
thanks, got it !
convertible 63
May 9, 2018 06:10 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
agtw31
Jun 23, 2009 01:39 PM
esisson
May 20, 2008 12:09 PM
