67 production start date
Well the reason I ask is because my car was invoiced on the dealers lot in Oct of 66. Not sure of the day but it was sold on 11/21/66. The car has a few 66 parts on the car that other 67's I have looked at that have late 66 builds do not have on their cars. I'm thinking a September build.
by my calculations:
Oldsmobile Lansing built around 1,600 cars-per-day (non-Toronado) when the plant was in full swing for the '67 model year. Were there 3-shifts, did all 3-shifts build cars? Production for the first couple of weeks (or month) was at a much slower rate with only around 3,000 cars assembled during the last 8 working days of August (08D & 08E). Has anyone seen a 08C built 1967 Olds? Approximately 30,000 units were built by the end of September '66.
On the other end - the first 3 weeks of July were similarly productive, but production during week number 4 (07D) decreased significantly to less than 3,000 units for the week. I don't believe there are any 07E '67 Oldsmobiles.
Does anyone know when the "public" introduction of the '67 cars was? This date was usually mid-September.
Also in strategic places on every body panel is a date code. I haven't researched a '67 but here is an example of one off of my '72
A22 = A machine 22nd week of '72 ~ last week of May 1972 and my car was assembled the 1st week of June
A21 = A machine 21st week of May (~4th week of May) of '72
![](https://lh5.googleusercontent.com/-csX3uQCs1tc/UXV9zE9nE5I/AAAAAAAAEbw/E252pdmihUs/s640/DSC02199.JPG)
G22 = G machine 22nd week
Trunk Lid underside - A22 34257 = A machine 22nd week Cutlass Supreme
I don't think there could be a 00A for the cowl tag. That would indicate the 'zero' month first week build. More likely the embossed numbers are a little light and it's 09 as Scot mentioned the possibility of.
One other thing I remember reading somewhere. Not all plants started production at exactly the same time. I believe Lansing was usually the first to make the transition to the new model year.
An invoice date of Oct 66 does indicate an earlier production car, but likely not one of the very first ones.
As Mike said the trim tag is stamped as clear as day 00A.
The quarters are stamped A39 and the rest of the sheet metal has that stamping also.
Vin is 130880 so it's not a real early car.
Mike is the car done yet.
Thanks for posting that tag. Looks like the car it came from WAS an early production with body 425 at Lansing. Can't help but wonder if that wasn't for the first week of August though. To have a production date in October with a low body number like that doesn't jive.
The A39 on all quarters indicates the same series of presses for the sheet metal stamping at Lansing Fisher Body works. You'll find those numbers strategically stamped at various locations on anything that was machine stamped prior to being welded into place. All the same numbers there means your car has basically all the same sheet metal it left the factory with.
If I'm not mistaken,cars were released in October back then. They built the 66 models until August 1,2 or 3rd. I have had a couple of 07E cars,so they built them very late in July or early August. They had to change the plant over to the next year model run,so how long did that take? Maybe DaveH can tell us that. My best guess is they didn't start producing the 67 models until September. I don't remember seeing a 08? 67 cowl tag but have seen a few 09? 67 cowl tags.
You can "wonder" all you want - the car was "produced" the first week of October. Based on the VIN (335677M134003) the car is a relatively "rare" Cutlass convertible with only 4,337 built - so "only" 425 units built at Lansing by the beginning of October (roughly 7 weeks into '67 production) is easily conceivable.
I don't know about that. If I assume Hurst68Olds numbers are correct, you actually would have an early production car. The sequence at Lansing started at 100001 for the 67 model year and 30,000 units could easily have been produced by the 3rd week of August if the 1600/day is accurate. Even if the actual number was closer to 1000 cars/day and assuming extra 4 hours a day production run time (around a car every minute and a half??) that would still be within the first month of 67 production..
Re-read my post - production was very "slow" at least 'til mid-September. Total production at Lansing (non-Toronado) for the month of August was in the neighborhood of 3,000 units. Total production at Lansing (non-Toronado) for the months of August & September '66 combined was less than 30,000 units. My numbers are within a few percent & definitely not off by nearly 40%. I don't believe there are any "08A" or "08B" Lansing built '67 Oldsmobiles & there may not be any for "08C" either.
Wow! Another 67 vert with an even lower body number. Wonder what happened to make the 00X mis stamping?
WAG - The first digit only needs to be changed a few times a year. Tired (Monday morning) UAW worker changing the 2nd digit (& 3rd) of the whatever type of "stamping fixture" from "09E" to "00A" & forgetting to the change the first digit.
With the 2 08D tags shown,that would seem right. Like I said before,they built 66's till the first few days of August. That would give them appox. 4 weeks for the model change over. Remember just because the body was built in August,the actual car production could follow by a few days or even a week or so. It's possible the bodies were built ahead of time by Fisher to get a jump on production. It also looks like your tag is a typo and with the serial #,I would say your car is a 10A car. Agree?
#33
I talked to Curt Anderson and has the production dates from Helen Early. The 67 F-85 production started on 8-25-66. Toronado production started on 8-9-66. He is sending me the 67 production by days of production.
#36
For some modern perspective, the 66 to 67 changeover is what my company would call a minor model change. (67-68 would be major). Current method, not including trial vehicles, is to clear the shop of vehicles (build out), allow time for conveyance to restock and tweak all flowracks and such, then start low volume build later that shift (like 1 in every 4 carriers, build about 30 or so the first shift). But, we build every work day, so their mileage may have varied back then.
#37
Here's 7M135893 another CS 442 2-dr hardtop (Holiday Coupe).
Nine 33817 bodies earlier & 5,000+ assigned VINs later. The body was built the same week, but notice the correct "10A" (at least someone had their machine properly set).
I'd estimate the bodies were built the same day, but the cars were 4 days apart.
#38
That is way too bizzare to have a trim tag that close to mine. Do you own the car?
From the info I have gathered from this thread and off line info my car was built around the 13th to the 15th of October. The body was built during the first week of October probably nearer the end of the week. All of the cast parts and other parts that are stamped with a date point in this direction.
The production start dates are at the end of August of 1966 for the 1967 year run.
Boiler_81
September 22nd, 2020 02:05 AM
ddd777
November 30th, 2013 12:21 PM
1320dragmonza
Tech Editor's Desk
August 17th, 2013 04:44 PM
