67 Olds Funny Cars End!
While readin a SS and Drag Illustrated November 67 Agent 1320 reported,
"Oldsmobile fans.you're in trouble. The two most famous Olds funny cars are out of competition, one permanently, one maybe not. The Hurst Hairy Olds which began coming on strong early in the year, was destroyed recently at a North Carolina strip after a wild ride. The Lutz 'n Lundberg 442 funny car has been retired and put on the block, with no decision yet as to its replacement. With the destruction of John Smyser's Terrible Toronado last Spring, that just about does it for this marque in funny car racing."
Agent 1320 didn't work long enough to meet Warren Johnson.
Ok not the same class of racing,,,but.
Two engines one car. Who has the ***** left?
Well I believe the twin engine Toro was the Terrifying Toronado and not the Terrible Toronado. Here is the reported final run of the HHO.... wow I thought it would have been more exciting and more flames. Glad the driver wasnt hurt.
1967 Hurst Hairy Olds - YouTube
Joe, I respect your experience, but anyone who's driven a Toronado in the snow would disagree with the statement above.
The constant problem with the Hairy Olds was fighting torque steer from all 4 wheels, and matching the throttle control between the two units.
The rear unit would try to drive around the front unit if they got it wrong, or had some sort of mechanical failure.
I will correct my prior statement, however. Spinning both back tires will also make directional control difficult. You really need all four tires to be ROLLING, not SPINNING - which is NOT happening in this photo.
True, up to a point. However, wheels that are spinning, and pointed in the direction you want to go, the car will turn. If it does push, you just let off for a second, and it will redirect. Of course, that won't work on the Hairy Olds.
Ask the guys who raced Toronados up Pike's Peak. Steve McQueen also raced highly modified Toro Front Drives in the Baja 1,000. They were mounted in giant dune buggy looking chassis. In all cases, the failure was always a small plastic gear in the tranny.
I know Toronados are not for everyone, but it always surprises me how little respect they get, even on Oldsmobile sites. I love 'em.
jensenracing77
October 25th, 2009 05:22 PM
