67 cutlass power antenna removal for car cover
Old Jan 28, 2013 | 02:24 PM
MudEye's Avatar
Arrow 67 cutlass power antenna removal for car cover
Hey Bought a car cover Heard the best way to get an exact antenna fit is to remove the antenna , place car cover on , punch hole for patch.
This one has a power antenna.Underneath the trunk I see 3 small screws on base(up top trunk ) But they are so small I can't see that helping anything.
Any suggestions anyone? Thanks
Old Jan 28, 2013 | 03:31 PM
Wouldn't it just be easier to lower the antenna?
I believe you just remove the mast nut and lower it into the trunk. There may be an additional brace inside but not sure.
Old Jan 28, 2013 | 05:27 PM
starfire's Avatar
You should just be able to lower the antenna and mark the area on the cover where the antenna is. Think about installing a plastic grommet instead of a patch. It will look much cleaner.
Old Jan 28, 2013 | 06:42 PM
Lady72nRob71's Avatar
Hmmm... One of the benefits for having a power antenna is not having to make holes in your cover...
Old Jan 29, 2013 | 08:59 AM
X4 or 5...
Isn't the whole POINT of a power antenna to be able to retract it????
Old Jan 29, 2013 | 02:24 PM
MudEye's Avatar
We'll I was under the assumption that the 67 supreme only retracted only so far,leaving a foot left on top.Unless mine is defective.It doesn't retract all the way.It goes up and down fine,but leaves a good foot left.Even if I try to force it a little.It just looks normal that way.Hopefully I'm wrong.You can see the antenna on the avatar picture.Would be nice if it would retract all the way.Maybe that is the question I need to be asking.
Hence my question.It's hard to get an exact spot with a foot of antenna keeping the right rear cover from seating correctly.
Old Jan 29, 2013 | 02:36 PM
Is the stock location on the passenger side, I thought they were on the drivers side and farther forward.
Old Jan 29, 2013 | 02:50 PM
gearheads78's Avatar
car guy
Pass rear 1/4 is factory.
MudEye's Avatar
This was a 1 owner person who never had any work done on it.The antenna is on the passenger side like the picture.I've seen other 67's with the antenna not all the way down.And some with no antenna's in rear at all(convertibles).So I'm a bit confused myself.Thanks Gearhead for clearing the location up.Is it supposed to retract all the way? Doesn't seem to.
Old Jan 29, 2013 | 05:08 PM
MudEye's Avatar
X4 or 5...
If it retracts This one doesn't At least all the way Over a foot left.
Old Jan 29, 2013 | 07:39 PM
Danny Boy's Avatar
1972 98 & 1984 H/O
Maybe the easiest solution is to sell me the car and cover for $1500
Assuming it should go down all the way; did you try soaking at the base of the antenna with WD40? I wouldn't force it to retract...the last thing you would want to do is replace a bent antenna.
Old Jan 30, 2013 | 07:22 AM
Then it's not working properly. It should retract flush with the bezel on the fender.
All factory power antennas that year were optional and mounted on the rear quarter. The fixed antenna was mounted on the front fender.
Old Jan 30, 2013 | 02:36 PM
MudEye's Avatar
Awww O.K. then.It looked so normal in that position,because it reaches so high up on the power up.Power down stops 12 inches from trunk.I thought it was normal that way.So then........ Wd 40 at the base as Danny suggested?
Or do I still need to remove the antenna(original question on how?)to troubleshoot it.
Or may there be another way of troubleshooting the power antenna.
It does work.Just doesn't work right I guess.
Old Jan 31, 2013 | 01:16 PM
Danny Boy's Avatar
1972 98 & 1984 H/O
Experiment different things...inexpensive thing...before removing antenna.
Try WD40
Try heating with hair dryer
Try cooling by spraying with upside down can of compressed air
Try heating and then cooling one right away after the other
I don't have a power antenna so I don't know the answer. Does the antenna twist at the base? Does each section that comes out of the base twist freely? If it is not meant to twist, don't do it. When the antenna is extended fully, I would wipe it down to remove any dirt or grime that may make it stick.
Old Nov 20, 2016 | 04:56 PM
MudEye's Avatar
X4 or 5...
This is the antenna....It does not retract all the way down into the trunk...unless it is faulty...
Thanks Joe!
Old Nov 20, 2016 | 06:08 PM
steverw's Avatar
I have 2 of these antennas, one functional one for parts. They unfortunatly do not retract all the way flush with the bezel. I think its just an early electric antenna thing, the antenna also electric on my 65 Vette does not retract completely. Not sure when they did start making them retract flush.
Old Nov 20, 2016 | 06:09 PM
Yellowstatue's Avatar
That looks the same length as '68 & '69 power antennae.
Old Nov 21, 2016 | 06:24 AM
MudEye's Avatar
You think I may have a 68 or 69 antennae then?
curtis mayfield
Feb 21, 2023 07:13 AM
Tallpaul67
Aug 7, 2014 09:16 AM
Switch Blade Betties
Mar 21, 2013 09:21 PM
Chesrown 67 OAI
Aug 6, 2011 06:58 AM
Bobac455
Oct 17, 2010 06:39 PM
