455 Valve cover removal with Power Booster question
Old Oct 8, 2010 | 12:35 PM
Bobac455's Avatar
I need to remove the valve covers on my 455. I haven't pulled the covers since I bought it last year and want to see what condition I have. On the driver's side, there is very little room between the rear of the valve cover and the disc brake booster. The valve covers are M/T ribbed. I find it impossible to get the valve cover off. Has anyone encountered this same issue? Do I have to remove the brake booster first? Any tips would be much appreciated. Thanks
Old Oct 8, 2010 | 12:40 PM
ScottMHoffman's Avatar
I ended up with a smaller diameter brake booster to solve the problem.
Old Oct 8, 2010 | 01:50 PM
442Harv's Avatar
If the valve covers are ribbed, they are aftermarket, and are probably taller. You may have to remove the booster.
Old Oct 8, 2010 | 01:59 PM
Warhead's Avatar
Remove the lower bolts, and loosen the upper bolts on the booster. It should give you enough room to sneak it out when you lift up the booster.
Jim
Old Oct 15, 2010 | 07:26 AM
Bobac455's Avatar
Geesh! Thanks but it is not what I wanted to hear. I believe my car started life with a 350 cu.in. Could this problem also be caused by a 455 transplant? I guess I'm really wondering if the 350's had a larger diameter brake booster than the 455's. I think replacing the booster with a smaller diameter one might be in order. Thanks for your comments.
Old Oct 15, 2010 | 07:34 AM
stlbluesbrother's Avatar
Is your car a cloned 442 from a Cutlass?
Old Oct 15, 2010 | 12:35 PM
Brake boosters are the same. The factory big block cars used "notched" valve covers to facilitate removal, though normal flat ones can be worked in and out with the booster in place. Again, your problem is that you have aftermarket covers that are taller than stock, since the ribs stick up higher than the stock sheet metal covers. Either pull the booster or pull the engine.
Old Oct 15, 2010 | 03:28 PM
BlackGold's Avatar
Wait until you try to replace rocker arms and pushrods on a 455 with A/C.
Old Oct 15, 2010 | 04:44 PM
Rickman48's Avatar
Valve springs and seals, in the car, w/air is even more fun!!
Old Oct 17, 2010 | 06:39 PM
dc2x4drvr's Avatar
Been there done that...wish I had Vintage Air...
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
jmills
Site Help
Mar 7, 2014 05:20 AM
Del70
Apr 28, 2013 05:02 PM
T butter
Feb 6, 2013 09:23 PM
Alg
Dec 29, 2012 11:01 PM
