66 throttle linkage
Old Jul 31, 2016 | 06:46 AM
Magna86's Avatar
66 throttle linkage
Ok guys since I have installed the BBO in the 66 with a performer intake and a demon carb its doesn't look like my factory linkage will work. Also have the some interference with my TV bracket and cable at back of the carb. So I'm wondering what some of you have done when installing BBO in the 66. Did you just make a custom rod or were you able to convert a cable somehow? I don't know a pedal you can swap in since the 66 pivot on the floor and not on a hanger like later years. Any tips and ideas will be helpful.
Old Jul 31, 2016 | 07:06 AM
What I do is make sure the linkage runs from idle to wot. I had to bend my gas pedal linkage by pulling up on the pedal a bit for it to open the carb all the way. I'm assuming the TV cable and bracket are separate and adjustable.
Old Jul 31, 2016 | 07:50 AM
young olds's Avatar
My 66 has a mounting area on the firewall for a hanging peddle, unless it was just a pivot point for the linkage. In any case a peddle from a mid 70's nova bolted right up so I could run a cable throttle. My car also had a hole/mount in the firewall so I used the cable off the nova too
Old Jul 31, 2016 | 07:52 AM
young olds's Avatar
The cable is stretched to its limit with a street dominator intake and a 1" spacer on my sbo
Old Jul 31, 2016 | 08:12 AM
Magna86's Avatar
I'll have to check my firewall as I'm not sure is has a spot for a hanger and cable mount but I don't remember seeing one.
Old Jul 31, 2016 | 08:48 AM
There are carb mounted brackets and cable sets you can buy aftermarket for adapting anything now a days. Treat it like any other Abody. The prices range from inexpensive to hi $$$$.
Old Jul 31, 2016 | 01:29 PM
TripDeuces's Avatar
Lokar makes a set up for a Chevelle of the same year that uses a cable. Of course with it you lose your transmission kick down feature as well as the Switch Pitch control if you're using the Jetaway. Of course this doesn't matter if you're running a manual trans.
Old Jul 31, 2016 | 04:27 PM
Magna86's Avatar
I'll have to look into that one TripDeuces. It would be nice to get rid of that setup since I'm running a 700R4.
Old Jul 31, 2016 | 05:03 PM
Can't you just run the stock carb linkage and the separate cable and carb mounted bracket for the 700R4?
Old Aug 1, 2016 | 02:56 AM
Magna86's Avatar
They are seperate but the TV cable interfers with the stock linkage when trying to attach to the carb. Not to mention the spark plugs in the area because of where the linkage pivot point/switch pitch control is. I have to look at it more when I get home later.
defiant1
Feb 4, 2020 08:53 PM
gearheads78
Aug 6, 2008 07:44 PM
66starfire
Apr 29, 2007 08:46 PM
66starfire
Dec 21, 2006 01:57 PM
1964 oldsmobile 442
Sep 5, 2006 11:19 PM
