66 442 E block 400, L2243 pistons TRW
Okay I just bought this car recently with a motor that has been rebuilt and run very little and think it sat for the last 20 years or better. I wanted to go through and check somethings before running it because it looked rough and intake gone. I am tearing it down and it has L2243 TRW pistons. Does anybody know how friendly these pistons will be on the street. What compression pistons are these. They are flat top pistons and .060 over. What other pistons could I go with, lower compression, that is out there and not cost a fortune.
Thanks for the help. Kelly
http://www.badgerpistons.com/
Those pistons will work well on the street. Check the distance they are down from the deck. Combined with a Fel Pro .040" gasket and a valve job (which usually results in 77-78 cc combustion chambers), your compression will be significantly lower than the factory advertised 10.5 to 1.
are you saying to run the badger pistons are the TRW pistons I have. Presently the heads on the motor are a set of A heads that are redone. I have a set of B heads that need a lot of work. i also have a set of C heads that I could bolt on, would they be better and maybe lower the compression or would they raise it. Is there a chance that the A heads are lowering the compression.
Kelly
Kelly
Kelly
Kelly
I was reading that the A heads have a different rocker arm setup. The heads I have must have some machine work done to them because they have the later model setup. I also read that they all are 80cc heads. I added a pic here so you can see the motor I am working on and it is rebuilt on the inside, it looks to be run a minimum on the inside.
Kelly
Kelly
j_link
August 18th, 2011 03:13 PM
