64 cutlass 330 motor question
Old Dec 27, 2024 | 09:17 AM
64CutlassConvt's Avatar
Hello Olds Folks, my 64 Cutlass 330 motor is an odd duck.
I'm wondering if the starter motor is unique to that motor or might
be common to other Olds or GM motors and where
I might look to get one.
Thanks for your help
Tom
Old Dec 27, 2024 | 09:27 AM
The 1964 330 has a lot of one-year-only parts (like the heads, shaft-mounted rocker arms, water pump, timing tab, and balancer), but the starter motor will interchange with those of any RWD 1964-90 Olds V8. Yeah, there are differences (high-torque on big blocks and the low-torque starters on the 307s), but they all bolt up and will work.
Old Dec 27, 2024 | 10:26 AM
Tri-Carb's Avatar
If it is for a manual transmission car, there is the issue of needing a case with a threaded hole outboard to attach the support bracket and clutch return spring. I am unsure if this applies to a 64.
Old Dec 27, 2024 | 05:18 PM
Sugar Bear's Avatar
If you have the correct starter, I'd suggest getting that one rebuilt locally not exchanged for a rebuilt unit.
Oldguy#4
Feb 21, 2024 10:39 AM
64CutlassConvt
Jan 9, 2023 05:59 AM
liquify33
Apr 22, 2022 04:00 PM
lunaboy
Apr 29, 2013 11:18 AM
optimus
Nov 30, 2011 09:51 AM
