62 Starfire firewall grommet
Old May 9, 2022 | 06:48 AM
dennis_30281's Avatar
Does anyone make a grommet similar to this one for my 62 Starfire firewall. This one is as hard as a rock and I don't think that it will slip into the firewall hole.
Old May 9, 2022 | 07:43 AM
jensenracing77's Avatar
Not that I am aware of. I believe it is the same as the f-85 of that year. Mine was hard but luckily it was still good enough to get it back in and not brake. There is a metal core to them if it is like mine was. I had to lube it really good to make it work. Is there a flat side to the hole in the firewall?
Old May 9, 2022 | 08:40 AM
Yes, flat side at the top. I'll grease her up, close my eyes and push. Thanks
Old May 9, 2022 | 10:58 AM
I had to put a long pry bar on it and tap it with a hammer to get it popped in.
Old May 9, 2022 | 11:00 AM
Old May 9, 2022 | 05:50 PM
Did the hole for the wires tighten up when installed
Old May 10, 2022 | 03:11 AM
I had the wire already in the grommet when I installed it but the harness fit a little loose in mine. It originally had lots of gummy sealer around the wire and all around the grommet.
Old May 16, 2022 | 05:34 PM
harwooddan's Avatar
I don't have a 62' but did you try Steele Rubber or another manufacturer ?
Old May 17, 2022 | 05:57 AM
Firewall grommet
Yes, I checked all the suppliers that I know off. The grommet is a weird shape, no wonder no one has reproduced it.
FTolliver
Jun 7, 2021 07:36 PM
mikeolds
Jun 12, 2017 06:28 PM
jensenracing77
Jun 30, 2016 06:12 PM
mishcar
Aug 10, 2015 02:54 PM
tpawlik
Aug 5, 2009 06:31 AM
