62 full size wiring question
So, I've got the dash out, and I'm installing a Rebel Wire kit.
Anyway, according to the 62 service manual, the panel connector has the following wires:
Pink: temp hot
Lt Green: Hi Beam
Orange: Oil
Brown: Generator
Yellow/black stripe: ?
Yellow: LH turn
Dk green: temp cold
Lt Blue: RH turn
Gray blk stripe: Fuel gauge
Gray: ?
New to this, so any help is appreciated!![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
See attached:
Pink: temp hot
Lt Green: Hi Beam
Orange: Oil
Brown: Generator
Yellow: LH turn
Dk green: temp cold
Lt Blue: RH turn
Gray: ?
See attached:
according to a '61 manual.. The grey wire is for the instrument lamps that light up the face of the cluster, ash tray lamp, ignition key lamp. The manual says the yellow / black stripe is for the left hand indicator turn lamp, while the yellow is for fuel gauge ( as well as the grey / black stripe ) and splits to the safety sentinel ( if so equipped)
