#6 heads vs #7A
Old Sep 22, 2015 | 11:32 AM
firsttimeoldsowner's Avatar
#6 heads vs #7A
Hi guys been awhile since I been on I've trying to run down parts for my car. Got a question I have a 72 cutlass supreme with a 350, I found on ebay a pair of #6 heads from a 1970 350. The bid so far is $220 plus $85 in shipping. Now is it worth it to try and get these heads or just take the ones I have on mine and get them worked on as in getting the bigger valves etc, or is there a big difference in cc and compression and valve size and how much would you guys pay for the #6 heads? Thanks again for all the help and advice!
Old Sep 22, 2015 | 03:31 PM
There isn't any difference in chamber size or valve sizes between the two. Personally, I would spend my money on the 7A heads unless you can't have the vehicle down while the work is being done on your current heads.
Old Sep 22, 2015 | 04:39 PM
Macadoo's Avatar
X2
If you want higher compression you'll have to mill the heads, deck the block, replace the dished pistons with flat tops, or a combination of the above.
Don't just throw parts at it, it's a waste of money (ask me how I know). Write up a plan, starting with your desired results, and work from there.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
