56 Olds 88 back glass question???
Old November 21st, 2008, 04:58 AM
Junior Member
Nailhead 88's Avatar
56 Olds 88 2 door hardtop back/rear glass question
what will interchange with it? i was looking at the contour of the roof line
it looks a lot like my 54 & 55 Buick Special & Century 2 door hardtops
Nailhead 88 is offline
Old November 21st, 2008, 10:28 AM
Junior Member
88 coupe's Avatar
Originally Posted by Nailhead 88
........ it looks a lot like my 54 & 55 Buick Special & Century 2 door hardtops
"B" body (Catalina, Holiday, and Riviera) 2 doors, from '54-'56, will interchange.
Don't know about the other body styles. Any automotive glass shop should be able to look it up for you.
Norm
88 coupe is offline
Old November 21st, 2008, 10:44 AM
Junior Member
Thanks Norm, it sure had the same look, here's the 56 Olds 88
Old November 21st, 2008, 10:46 AM
okie88's Avatar
My interchange book shows that the 56 Olds 2 Dr Hdtp will interchange with 54 & 55 Olds 2 Dr Hdtps and 54-56 Buick Special & Century 2 Dr Hdtps.
Mike
okie88 is offline
Old November 21st, 2008, 05:26 PM
Junior Member
Mike
Good to know to know Mike, i'll have to go to the yard and do some hunting
Old November 24th, 2008, 04:47 AM
Junior Member
How do you install a back glass?
On a 56 Olds 88 hardtop do you have a gasket that goes around both sides of the glass & use the rope to spread the lip and seat it on the pinch weld? Does the stainless window molding go in the rubber gasket?
Never did a back glass, have done 57 Chevy windshield's before. 47 Buick windshields go in from the inside & the windshield garnish molding holds it in. Is that a possibility the glass goes in from the inside?
The reason i'm asking about the back glass the car is 850 miles from here, i noticed in the photo that the back glass stainless molding is still installed on the car & the glass is gone
Old November 26th, 2008, 12:04 AM
Junior Member
88 coupe's Avatar
........ a gasket that goes around both sides of the glass & use the rope to spread the lip and seat it on the pinch weld? Does the stainless window molding go in the rubber gasket? ........
Yes and no.
........ the windshield garnish molding holds it in. Is that a possibility the glass goes in from the inside? ........
No and no.
........ stainless molding is still installed on the car & the glass is gone
Likely the window shattered window and the rubber is still in place.
Norm
88 coupe is offline
Old November 27th, 2008, 07:53 PM
Junior Member
Thanks again Norm, makes sense, i can handle it now
scharpp
March 2nd, 2015 08:11 AM
scharpp
February 4th, 2015 06:53 AM
rcdynamic88
February 24th, 2014 10:32 AM
shovel55
November 21st, 2010 06:00 AM
Nickthefish
October 16th, 2009 06:15 AM
Quick Reply: 56 Olds 88 back glass question???
