56 Olds 88 back glass question???
Old Nov 21, 2008 | 04:58 AM
Nailhead 88's Avatar
Junior Member
56 Olds 88 2 door hardtop back/rear glass question
what will interchange with it? i was looking at the contour of the roof line
it looks a lot like my 54 & 55 Buick Special & Century 2 door hardtops
Old Nov 21, 2008 | 10:28 AM
88 coupe's Avatar
Junior Member
Originally Posted by Nailhead 88
........ it looks a lot like my 54 & 55 Buick Special & Century 2 door hardtops
"B" body (Catalina, Holiday, and Riviera) 2 doors, from '54-'56, will interchange.
Don't know about the other body styles. Any automotive glass shop should be able to look it up for you.
Norm
Old Nov 21, 2008 | 10:44 AM
Junior Member
Thanks Norm, it sure had the same look, here's the 56 Olds 88
Old Nov 21, 2008 | 10:46 AM
okie88's Avatar
My interchange book shows that the 56 Olds 2 Dr Hdtp will interchange with 54 & 55 Olds 2 Dr Hdtps and 54-56 Buick Special & Century 2 Dr Hdtps.
Mike
Old Nov 21, 2008 | 05:26 PM
Junior Member
Mike
Good to know to know Mike, i'll have to go to the yard and do some hunting
Old Nov 24, 2008 | 04:47 AM
Junior Member
How do you install a back glass?
On a 56 Olds 88 hardtop do you have a gasket that goes around both sides of the glass & use the rope to spread the lip and seat it on the pinch weld? Does the stainless window molding go in the rubber gasket?
Never did a back glass, have done 57 Chevy windshield's before. 47 Buick windshields go in from the inside & the windshield garnish molding holds it in. Is that a possibility the glass goes in from the inside?
The reason i'm asking about the back glass the car is 850 miles from here, i noticed in the photo that the back glass stainless molding is still installed on the car & the glass is gone
Old Nov 26, 2008 | 12:04 AM
88 coupe's Avatar
Junior Member
........ a gasket that goes around both sides of the glass & use the rope to spread the lip and seat it on the pinch weld? Does the stainless window molding go in the rubber gasket? ........
Yes and no.
........ the windshield garnish molding holds it in. Is that a possibility the glass goes in from the inside? ........
No and no.
........ stainless molding is still installed on the car & the glass is gone
Likely the window shattered window and the rubber is still in place.
Norm
Old Nov 27, 2008 | 07:53 PM
Junior Member
Thanks again Norm, makes sense, i can handle it now
scharpp
Mar 2, 2015 08:11 AM
scharpp
Feb 4, 2015 06:53 AM
rcdynamic88
Feb 24, 2014 10:32 AM
shovel55
Nov 21, 2010 06:00 AM
Nickthefish
Oct 16, 2009 06:15 AM
