53 olds wiring
Old Aug 9, 2019 | 05:52 AM
aqua67w30's Avatar
53 olds wiring
40yrs ago we took the steering column out of my Dad's '53 Olds Super 88. There are 6 wires that come out of the column under the dash. I know that 3 wires are for the Hydromatic indicator and 2 wires are for the turn signals. The 6th wire is tan with a black and red cross tracer and I don't have a clue where it plugs in.
Old Aug 9, 2019 | 08:28 AM
Yellowstatue's Avatar
18 ga BRCT signal sw to flasher. Try that.
Old Aug 9, 2019 | 01:04 PM
aqua67w30's Avatar
The horn wire comes outside of the firewall and connects to the horn relay. This wire comes out inside the car on top of the column with turn signal and hydro wires.
Old Aug 9, 2019 | 05:38 PM
The other BRCT wire is 14 ga. and runs from headlight switch terminal 4 to dimmer switch terminal B. As per 1953 chassis manual PSD-53-2, page 13-34 fig 13-44 . As posted above, wire goes from signal switch to flasher. Is the wire long enough to reach the flasher?
Old Aug 9, 2019 | 07:31 PM
aqua67w30's Avatar
The wire is long enough to reach the flasher. I'm looking at the wiring diagram and I see what your looking at. The car is in Pa. and I'm in Oh. but I hope to be there next week. I'll see if there is a place to plug into the flasher.
Old Aug 26, 2019 | 07:46 AM
aqua67w30's Avatar
Thanks Yellowstatue. I plugged the 18 ga. BRCT into the flasher and matched up the others. Everything works except Hydro indicator. I believe I have it wired properly. I'll have to double check it next time I visit. All gauges,lights, turn signals, backup lights and neutral safety work. We took it for a drive for the first time in 41 yrs. Dad had a big smile on his face.
Old Aug 26, 2019 | 06:44 PM
Glad it worked. Now I can get a decent nights sleep.
Aug 2, 2018 05:04 AM
70Post
Jul 23, 2018 08:03 PM
cbogartjr
Aug 6, 2016 04:48 PM
sealw98
Jun 16, 2016 06:32 PM
tschie
Tech Editor's Desk
Nov 11, 2015 04:35 AM
