496 Stroker
496 Stroker
There's a 70'Cutlass for sale with a 496 stroker that was used for drag racing. I realize a lot of money was put into the build but I'm not sure if I should buy the car because I do not know the engine condition (even though it looks good in picture), plus I plan on abusing the power.
Would the best choice be to sell the engine and use the cash to get an olds 455 plus other goodies? Or would it be better to use the 496 and take it to the shop for maintenance? Thanks for reading
A 496 built for drag racing can only do one thing . Take you 1/4 mile in the fastest time . I don't think it would be practical on the street.
I think your idea of selling the 496 and getting someone to build a streetable 455 is a good one . If you want to enjoy driving the car .
A lot depends on how you want to use the car .
If I want something that'll perform well under heavy wear with atleast 375hp, would a 350 suffice or would I have to get a 455? (Budget 5-6k)
My 496 is plenty streetable as are dozens more here. Why would you think a 496 isn't streetable? My cam at 242@ .050 might be ragged for a smaller engine but right at home in a 496.
What cam is in this 496?
As long as the comp ratio is reasonable and doesn't need race gas or anything, you can make anything fairly streetable. It won't be a daily driver, will it?
Check the engine over well, figure out who the builder was and do some homework.
Tearing it down for a check over isn't a bad idea either.
You could be thousands ahead of the game.
-pete
I like this route.
-pete
-pete
I believe someone once said "There's no replacement for displacement"
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
I have no doubt that streetable 496's can be built. My advice was based on the theory that the 496 might bring enough money , to the right buyer , to darn near build TWO 455's that produce " at least 375 HP ".
Crazy thought but would a Chevy 454 be better since they can produce massive power with the right engine parts? Or will that be too much of a hassle?
The OP told me he had a " 496 built for drag racing " . That meant , to me , that it would have a very radical cam , compression somewhere up in the stratosphere , and some kind of a "megasquirter " or such carb that only works well at full throttle . Why would anyone build one any other way if they were seriously going drag racing.
"but would a Chevy 454 be better since they can produce massive power with the right engine parts?"
No. A chevy 454 making "massive power" is as unstreetable as the "drag race" Olds 496.
", plus I plan on abusing the power."
But you just want 375 hp?
Maybe to get the best help you should post the specs of the 496. "Drag race" engine could mean anything. I'm with Rallye469 on the best build.
Oldsprepp
May 22nd, 2008 07:37 AM
shaks 442 clone
March 31st, 2008 08:02 PM
