455 water pump plate
Is this the right water pump plate for my 1972 455 oldmobile...it was on it when I bought it and the engine was used in a jet boat but now had been put back in a car...ps it was cleaned up so its not like the picture its clean now...I just need to know if its the right one you have on a car..thanks
1972 455 water pump plate help needed
Is this the right water ] plate for my 1972 455 oldmobile...it was on it when I bought it and the engine was used in a jet boat but now had been put back in a car...ps it was cleaned up so its not like the picture its ] now...I just need to know if its the right one you have on a car..thanks
Edit: In looking at the photo again, it looks like several of the 1/4-20 self tapping bolts have been enlarged. You might want to verify this, as the larger bolts likely won't fit through a stock water pump. Only the four (two above and below each water port) are supposed to be large ones.
FYI, it still is neither necessary nor in your best interest to ask the same question in multiple forums. You'll get a better answer faster if all responses are kept in one thread so that incorrect info can be caught and corrected quickly.
if thats the plate im good..as I have attached a stock water pump already to it and everything bolted up fine...I was just wondering if that plate looked right as my 455 is overheating and I have a new thermostat new water pump new champion 4 core radiator new hoses the engine has been power flushed it has a shroud on it and a new clutch fan with a steel blade fan..only thing I can think is the car needs to be tuned and the timing adjusted and the shroud needs more tightening up
Nor Cal Andy
March 29th, 2012 07:27 PM
