455 info needed
Old Sep 22, 2013 | 03:44 PM
70cutlass's Avatar
455 info needed
Hello all
Not sure if this the right place to post this but could someone tell me if there is a difference between a 1971 455 out of a cutlass, and one out of a 98 or 88. Can I achieve the same HP/torque , is it worth rebuilding or is it a waste of time. is there anything I should look out for.
Old Sep 22, 2013 | 05:52 PM
pogo69's Avatar
morgan
Im pretty sure in .71 you could get a high or low compression in the A body not sure about the B body...but the engines are the same other than different components ...starter,alternator...if the car had a/c etc
Two vs four barrel carbs and manifolds could be different
Old Sep 22, 2013 | 05:57 PM
Grace Stinespring-Welch's Avatar
if you build it right, you will not have problems, [usually.]
Old Sep 22, 2013 | 05:59 PM
I swear I just saw and answered this question.
Did you, perhaps, post two identical threads?
And, no, Pogo, only low compression 455s were available in 1971.
Old Sep 22, 2013 | 07:06 PM
pogo69's Avatar
morgan
Ok , thx for the correction must of been 70 then?
I guess that was a shame for the 71 model, the HP took a hit then
Old Sep 22, 2013 | 07:43 PM
'70, for sure, but I checked the '71 CSM before posting the answer in his other thread, and they were definitely 8.5:1 across the board.
There were some other makes that still had some high-comp. motors in 1971, though.
Old Sep 22, 2013 | 08:11 PM
svnt442's Avatar
If you plan on a rebuild it really doesn't matter as you can install whatever pistons you want to.
cobalt
Sep 24, 2013 10:56 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
76ttop
Feb 5, 2007 11:29 AM
