455 head stud for heat shroud
Old Mar 14, 2013 | 07:23 PM
charlierogers's Avatar
1970 442, looking for the correct head stud {pass side} that holds the cold weather heat shroud in place. are they all the same on 455 bbo? thanks AGAIN for any help guys!
charlie,,,
Old Mar 15, 2013 | 07:50 AM
bump
Old Mar 15, 2013 | 03:27 PM
BlackGold's Avatar
The small heat shroud which attached to the center head stud on the right-side head was only used on A-bodies, not 88s, 98s, or Toros. For that reason, the stud was only installed on the A-body engines. The other 455s got a regular head bolt in that position.
However, that head stud is identical to those located one position forward on both the right and left heads. So it shouldn't be that hard to find one. for what it's worth, the stud's part number is 383038.
Old Mar 15, 2013 | 05:32 PM
thats very interesting. what was the purpose of the other special studs?
Old Mar 19, 2013 | 03:41 PM
BlackGold's Avatar
The other two studs are used to mount the alternator and A/C compressor brackets.
RAMBOW
May 27, 2017 06:11 AM
The Bug Man
Jun 25, 2014 01:34 PM
EightballZ
Mar 24, 2014 05:03 PM
GTA_doum
May 18, 2012 02:36 AM
Al Graaf
Sep 14, 2011 04:37 AM
