403 short block
Old Jun 12, 2026 | 05:42 AM
cloudshe's Avatar
403 short block
newbie here. asking for anyone who has replaced their 70's vintage olds 350 with a 403 short block. trying to plan a project! thanks!
Old Jun 12, 2026 | 01:45 PM
It’s an easy swap, should be pretty straightforward.
Old Today | 10:01 AM
They are externally identical. The only substantive difference is that the 403 uses 1/2" head bolts, so you will need to open up the 7/16" holes in early heads if you are going that way. Of course, the 403 is the lightweight block with thinner walls and windowed main webs, so not as strong as the 350 block. The cylinder walls are thinner, so overbores are limited.
Via3d
May 20, 2018 08:02 AM
1970-W30
Jun 27, 2013 09:32 AM
olzman
Jan 7, 2009 07:27 PM
olds4life
Jul 28, 2008 08:13 PM
Vics86
Oct 31, 2006 04:50 PM
