4 post lift
4 post lift
What 4 post lift gives the best bang for the buck?
I'm looking to add a 4 post lift to go along with my 2 post and I want to find the best recommendations from the folks here that have/ use a 4 post on a regular basis.
This will be for home hobbie use only.
Thanks for any replies
Thanks for your responses. Thru to little research that I done so far the only one that I would count out would be the Triumph lift due to the fact that it is not ALI/ETL certified. I want the piece of mind that which ever lift that I end up with is certified.
I'm most likely gonna wait several months before I buy.
Thanks again
Thanks again
Jerry, I had the same concern until I talked to all of the companies and learned what the ALI/ETL certified lifts really means. Especially when I asked the companies why they sold both ALI/ETL certified and non-ALI/ETL certified. Also, I talked with many of the installers who these companies independently hire to install their lifts so I could get additional input. And we made the decision at our company that stores tens of millions of dollars of cars on lifts, to go with non-ALI/ETL certified. Just make sure you understand where your money is really going when you make your final decision.
