394 heads
Old Sep 26, 2021 | 01:49 PM
dennis_30281's Avatar
394 heads
I found the number on the left head "20". Now what's the difference between a "20 and a "23"
62 Starfire 394
Old Sep 27, 2021 | 07:46 AM
Charlie Jones's Avatar
Phantom Phixer
I think the #20 head was for a 1961 Starfire .
It had smaller valves than #23 which was used in all '62 thru '64 394's .
Post the number stamped in the center of head and I can tell you more
Old Sep 27, 2021 | 04:37 PM
This 394 engine block casting number's ending in "4 1/8 with the number "20" on the heads which is a 1961 Starfire engine, low compression, so a 394 engine block casting number's ending in 4 1/8 with "23" heads is a 1962-1964 Starfire, high compression? Am I close
Old Sep 27, 2021 | 05:30 PM
Phantom Phixer
The 1961 Starfire had 10.25 to 1 compression and #20 heads .
All 62 thru 64's had #23 heads , whether they were high or low compression .
The piston dish depth , or lack of one , was what determined the compression ratio '
1962 and earlier engines had cast iron timing chain covers , 63 & 64 were aluminum .
Old Oct 3, 2021 | 12:20 PM
Thanks Charlie
dennis_30281
Sep 26, 2021 06:32 PM
dorvin
Sep 9, 2015 07:06 PM
Ralph Mack
Feb 17, 2013 08:08 AM
sborruso
May 20, 2010 08:29 PM
SMOKEYMTNKUSTOMS
Oct 12, 2006 11:56 AM
