350 just dies for no reason?
Old Nov 24, 2013 | 09:22 AM
44TEETWO's Avatar
Cool 350 just dies for no reason?
Good morning all,
I have an issue that is baffling to me. 350 starts right up, drives fine but without warning it will either stall and not re-start, or if I park it warm and come back out shortly, it will not start. If it sits for 15 min to a half hour it starts right back up. I have changed the fuel pump, and the hoses to the carb as well as the fuel filter. Any ideas? It doesn't seem like its getting fuel?
I really like driving the car but I can't depend on it not stranding me, HELP! LOL.
Old Nov 24, 2013 | 09:25 AM
RetroRanger's Avatar
72 Olds CS
Non vented gas cap ? Next time it dies try loosening the GC and see if it will restart or makes a whoosh sound
Old Nov 24, 2013 | 09:29 AM
44TEETWO's Avatar
Has factory cap but I will check that! The car sat for 11 years before I got it. So I flushed the cooling and fuel systems. I keep searching. THANKS!
Old Nov 24, 2013 | 09:40 AM
tru-blue 442's Avatar
Old School Olds
You didn't say what year.
Hei or points?
The electronic module under the
cap on an hei could be bad. They
act up and lose fire after running
awhile. Or the condensor for the
point set-up can cause the same problem.
Usually will fire up again after they have
time to cool off. Good luck and let us know
if you got it fixed.
Old Nov 24, 2013 | 09:53 AM
44TEETWO's Avatar
1977. It is HEI, Changed the cap and rotor, didn't change the module under the cap. I have another complete dist. I will try that! Thanks.
Old Nov 24, 2013 | 10:20 AM
Old School Olds
I would not change the complete dizzy,
just the module.
Old Nov 24, 2013 | 11:04 AM
Funkwagon455's Avatar
just the module.
I was on the same page with your first reply, and now with this one. My money is on the module.
Old Nov 24, 2013 | 11:15 AM
billmerbach's Avatar
major noob
Holy crap I'm having this problem on my dads gran fury same troubleshooting but we changed the module 3 times and its still happening we also changes timing chain fuel pump coil distributor etc etc
Old Nov 24, 2013 | 11:21 AM
Old School Olds
Can't help you on that one Bill.
Me no Know Mopar's.
Maybe Eric or even Eric may chime in.
Old Nov 24, 2013 | 11:22 AM
major noob
OK thanks really need input from you guys who might know its my dads did and my transportation to work and no work no money no car
Old Nov 24, 2013 | 01:00 PM
When you say does not start, does it crank? Did you pull the air cleaner off and while looking down into the carb operate the throttle and see if you had fuel? Do you actually have spark when your cranking the engine? If you have a known good distributor, I would drop in whole instead of just changing the module.
This applies to the Mopar too.
Old Nov 24, 2013 | 01:30 PM
+1. I hear a lot of parts changin', but no troubleshootin'.
Is it getting fuel? Does it have a spark? We don't know. Do you?
Yes, the HEI module definitely has a failure mode like that, but why not check for spar, then, if you have none, take the module down to your local chain parts store and have them test it, and, if it tests bad, replace it? (Have them test the new one before you leave the store, too - ask how I know.)
Old Nov 24, 2013 | 01:48 PM
Sampson's Avatar
X2 on the troubleshooting. Check to see if it squirts gas in the carb. The way you describe the way it happens with the engine warm it sounds a lot like vapor lock. How are your fuel line routed?
Old Nov 24, 2013 | 02:26 PM
RROLDSX's Avatar
Mopar's are notorious for bad ballast resistors. They get corroded in the back. Try that one.
Old Nov 24, 2013 | 02:30 PM
major noob
Ok thanks haven't tried that
Old Nov 24, 2013 | 02:33 PM
major noob
Correction we have changed that
Old Nov 24, 2013 | 09:05 PM
44TEETWO's Avatar
Checked for spark and it was ok, it acts like it is getting no fuel, but it is. Engine doesn't have too be very warm, one time it did it in less then one mile from home, stalled and would not start, (yes it turns over just fine) then after leaving it for a while, it starts on less then a full rotation like nothing was ever wrong? I am leaning toward the module issue, I have at least 3 in my shop! I have never seen one act so odd but I will give it a shot! Thanks for all the ideas, I will let you know what develops.
Old Feb 4, 2014 | 06:14 PM
"Well…….We're waiting!!!!!!" (Ted Knight, Caddyshack)
Old Feb 4, 2014 | 08:14 PM
LOL, kinda curious to what the issue might have been also.
Old Feb 5, 2014 | 04:30 AM
Old School Olds
Where did he go George,
where did he go...(Looney Tunes.)
Old Feb 5, 2014 | 05:54 AM
68oldscutlass's Avatar
Wondering about this as well. I was kind of thinking it sounds like a choke issue. Like it is getting stuck or just working improperly. Especially when you said it has to cool down to start. Just a thought but hey, definitely curious. To many forums out there that have the problem but not the final result. Check in with the answer dude!
Professur
Feb 7, 2014 07:16 PM
kevin.horton
Jun 15, 2011 04:05 PM
jeffreyalman
Aug 28, 2009 06:14 PM
emarkay
Dec 8, 2004 08:23 AM
