350 help
Old Sep 14, 2010 | 05:38 PM
new2thegame's Avatar
350 help
so far i love the forum i need a little help long story short i got this motor from my buddy its a olds rocket 350 2 bolt main year 77-80 not sure on what the motor came out of but i got the motor for a good price to FREE i love free stuff win i got the motor back to my house it only had 1 bolt holding the heads on so i took the bolts out looked at the it has a fresh rebuild on it it is punch 30 over already i have been doing a little homework on it and i know its not the best motor to build but all motors have cons i know it has a oil psi problem after 5000 rpm i know that the term "rocket" has nothing to do with the motor being built any better the part i need help with is all the brackets are missing off the motor a lot of the bolts,no carb,no trans,etc i have looked at all the motors in the junk yard all the olds in there have the 307 and are from mid to late 80s do any of the parts work on the 350 and do any of the other small block chevy,pontiac,buick parts or trans work any help would be nice thanks
Old Sep 14, 2010 | 06:08 PM
lshlsh2's Avatar
71 cutlass convertible
I believe you will need olds parts for your olds moters. The good news is most it not all the brackets on a 307 will work on your 350 provided that the options on the engines are the same.
Old Sep 14, 2010 | 06:16 PM
The trick with Oldsmobile accessory brackets is that the water pump length and the pulleys must match the brackets. In other words, you need to transfer everything from the 307 - pump, pulleys, and brackets - to ensure the belts line up. The 350 and 307 are externally identical, so everything swaps easily. The only thing Olds motors have in common with Chevy, Buick, or Pontiac motors is the distributor cap. Well, the Pontiac uses the same starter.
Olds does have the same BOP bellhousing bolt pattern, so an Buick, Pontiac, or Caddy RWD trans made since 1964 will bolt up.
Old Sep 14, 2010 | 06:27 PM
thanks for the info guys
nolabigdawg
Nov 16, 2014 06:45 PM
a69
Jun 11, 2012 12:09 AM
MJAKS462
Apr 15, 2010 02:34 PM
dharlett
Sep 23, 2009 03:30 PM
<Eddie>
Nov 1, 2005 07:30 PM
