-35 degrees..will the 64 survive
So my garage is unheated. The 64 88 will have to survive -35 degrees Sunday and Monday. Will the anti freeze be enough. These are the thoughts keeping me up at night. Hate to crack a block. I think it is time for a space heater and a warm blanket over the gal. Any thoughts
If you don't have a good antifreeze tester you should get one. A few bucks to verify how good your antifreeze is may save big bucks down the road. I've had stuff that was still green but due to age wasn't up to the task anymore.
Tonight on the evening news they were talking about somewhere in the mid-west where the high temp was predicted at -8. I can't imagine the motor oil doing its job when you first start the car. A block heater would be a good investment for places that get that cold!
I remember about 25 years ago north of Detroit, the temp got down to -50 with the wind chill. They were anouncing on the news that it was so cold that people with radial tires could not drive. The bump at the bottom of the tires were freezing and making them undrivable.
There are heated dip sticks and "tank" heaters that mount in the coolant return lines (simple and inexpensive) you just plug them into an electrical outlet. the car will start like it's spring time! If the car is sitting in a parking lot at those temps, start it up and let it run during lunch break. Or just get smarter and move where the temps do not get that cold! ;-)
Dave
Dave
Wind chill:
: a still-air temperature that would have the same cooling effect on exposed human skin as a given combination of temperature and wind speed —called also chill factor, windchill factor, windchill index
The ambient temperature is what your car oil and anti freeze feels, not the wind chill... Pull the dipstick at those temps with caution (and gloves!)... I still feel the frostbite after 30 years
X2. I hate cold weather. We are -5 this morning so I started the wood stove up to help out the heat bill a little. I would move south in a second if i didn't have so many roots here.
My car sits all winter. I need to move it today and I will plug it in first, only -9C today. Ah the joys of the most extreme climate on earth. We have +45C occasionally in summer and -45+C in the winter.
Are you sure about this? According to this chart
http://www.magers.org/handy/antifreeze.html
a 50/50 mixture is good down to -34 F. At -35 F, you're right on the edge.
Hard for me to comprehend those below zero temperatures, took a 30 mile trip with the top down today, temps in the low 70s in Scottsdale. Makes putting up with our 105+ summer temperatures doesn't seem so bad now.........
If you were just storing the car would it pay to drain the coolant?
Last night -26 with windchill -31
The south is looking better all the time when I retire!
Better start saving now for insurance!
X2 on the block heater
Just head to the Arctic where it hits -70! Now -50 doesn't seem so bad. That is why I said at least 50/50, as said it will get slushy possibly but not enough to do damage. If you are not starting it, unhook to battery. I had one freeze and second was close. Charging them every now and then helps.
#31
I'm with '70-W-30 with those temps like that, it make my hands and feet hurt just reading them.
I use a block heater here in Calif and it only gets into the 30's and maybe once in a while a high 20 something.
I grew up in the Chicago area and left for Calif when I was 18 and never came back. Man I just don't know how you guys do it, way to cold for me.
On another note I'm going drag racing on Sunday. It is our first Summit ET race. Should be about 62* I think.
Gene
Gene
#33
OK here is what I got from all the posts...Go South Young man go south. I will bring in Battery to my house. I will recheck radiator coolant status. I purchased an oil filled heater @ $60 bucks and will place it near front of car. Then kiss my girlfriend and head to vegas
#34
i always run my antifreeze mix up so the freeze point is at least -55F, yeah, they say it doesn't cool as well in the summer, but i've never had a problem with anything i've ever owned. my momma only raised one idiot, and that's my brother. he cracked a 330 in a '65 cutlass that my dad sold him, by running straight water in WY wintertime.
bill
bill
#35
living in Burlington Vermont we used to up the antifreeze mix to about 60/40 in winter and drained some coolant in late spring and thinned it back to about 50/50 for summer... If you had a beater for winter, had it sprayed in late fall with drain oil underneath and in the panels to keep rust at bay. Had sand tread recaps for winter tires. (cap had sand imbedded in the rubber.. could get 2 winters out of them, changed out in spring)
#36
Car owners have been fighting these temps for many years and have typically came out ok. Would recommend testing the antifreeze or beg a friend with a heated garage or storage unit if you could "borrow" it for a while. Space heaters can be dangerous but maybe ok if used in moderation and watched closely
#37
Yep, to many of these dang things, too, esp this year! Going outside is a challenge.
I like the Pacific NW at the coast - no arctic blasts (or very rare) and no hot humid crap. Bugs are not bad either.
Run the car, then pull the battery and move inside.
Those oil filled radiator heaters are the best and safest for unattended use. I have used them for years.
A 100W bulb on the concrete floor under the oil pan can help, too.
#38
Quick update: Radiator fluid tested at -30 so I feel confident. I placed a thermostat under the engine compartment and it read 8 degrees. The temperture outside at the time was -19. Seems (as many people have noted) the concrete in the unheated garage is warmer then the garage itself...thus the cause for condensation under the car. Another point of support for placing thick plastic under your car when stored.
