330 engines and desirability
I don't hear alot about these mid sixties SB Olds engines. How desirable are they? Were they prone to problems? Were they not popular in a Cutlass or F85
I don't think the 330 was particularly unpopular. It was new for '64 and was the base V-8 in the A-body cars through 1967. The 330 was also offered in the full-size '64 through '66 Jetstar 88 and later '67 Delmont 88. Many tens of thousands of Oldsmobiles were built with them.
I think the only reason they don't get much attention now is because the 350 is more modern and is so much more prevalent and easy to get parts for. The 330 was offered for only four model years ('64, '65, '66, and '67) while the 350 was offered for 13 model years ('68 through '80). There were literally millions of 350's made.
The 330 high compression is a very good engine. The 67 had 320 hp with 10.25:1 compression and a forged crank. As mentioned above the 350 is more plentiful and people use the crank out of the 330HC in SBO builds because of it's strength. Pistons are expensive for the 330 and the block can tolerate a .060 over bore. The early 330's had a different cam bank angle, lifter diameter, and valve train components, so be careful with parts compatibility.
330 Engine
Rebuilt and installed a 67 330 cid engine into a 68 Cutlass. Parts are more expensive but worth it. I found a lot of parts store associates trying to sell me parts and gaskets for a 350. I believe different years had different cam bank angles (39 / 45).
The link below is an excellent Olds engine resource.
http://www.442.com/oldsfaq/ofeng.htm
As for the Olds FAQ, much of the info in it is even correct...
I have pulled apart many 330 engines and have never seen a .921 lifter 330. I have broken down 64,65,66, and 67 engines and they were all .842 lifters. Sure you guys are not confusing the early 330 with toro 425s, or 400s?
GEARMAN69
August 10th, 2022 05:39 AM
mashbaugh
September 17th, 2012 08:40 AM
