3 core radiator application.
Old Feb 11, 2017 | 05:19 AM
tru-blue 442's Avatar
Old School Olds
I have these old Harrison cores I am trying to figure out what the fit
and possibly offer them up for sale. Anyone know?
Old Feb 11, 2017 | 07:40 AM
76olds's Avatar
Hookers under Hood
I can see none of them have been recored , core sizes would help. I recall re coring many rads in the early-mid 80's when I was just a teen working in a local rad shop every summer.
Core sizes would help me, but if I had to take a wild guess, the one against the wall would be G.M., the other two look to be Ford, but this is just a guess not be able to see the complete rad upper and lower tanks with core sizes.
Eric
Old Feb 11, 2017 | 08:09 AM
2blu442's Avatar
Cool, they still have the tags on them! The middle one codes are familiar, although I can't remember for sure what the application is. I believe its 1971-72 Cutlass/442. Yes, please post how many rows are in the cores.
John
Old Feb 11, 2017 | 08:25 AM
76olds's Avatar
Hookers under Hood
I don't remember recoring many rads older than 73 back then, I'm sure I did but don't remember. I did so many mid to late 70's everyday.
I'm just looking at the top tank height, the trans cooler positions and the overflow pipe to try and determine at this point .
Eric
Old Feb 11, 2017 | 08:59 AM
Old School Olds
John
They are all 3 core, I have had them for many years and I think all
came from various year Cutlass/442's that had been parted.
Old Feb 11, 2017 | 09:19 AM
Old School Olds
Measurements.
Old Feb 11, 2017 | 11:14 AM
Mr Shifty Sidney's Avatar
I believe the middle one is from a 70 Cutlass/442/Vista. The FE code is listed in the 70 inspectors manuals. The other two have a different style metal tag that is not consistent with the ones I have seen on 70-72.
What is the letter between the C A on the FE radiator?
Hope this helps.
Don W
Old Feb 11, 2017 | 12:29 PM
Old School Olds
Don shows A O and underneath the steel tag it is embossed similar to the CA but smaller.
Old Feb 11, 2017 | 12:53 PM
Sorry I was not very clear. Hear is a picture showing the area I was asking about. There should be a letter embossed in tank. This is a date code.
Thanks,
Don W
Old Feb 11, 2017 | 01:18 PM
Old School Olds
Best I can tell it may be an O.
Old Feb 13, 2017 | 02:32 PM
RocketDevo's Avatar
Rad Code Tags
As Shifty Sidney pointed out the "FE" rad code tag is for 1970 models. I believe it is also correct for 1968 and 69 model years. The specific application is "V02", "Y72" and AC when it is a 3 core. The tag will have 2 sets of 2 letters. It will tell you the corresponding tanks that go with the tag. The driver side will always be "IA" or blank and the passenger side will be to each application. In this case it is "CA" As pointed out earlier the number between the "CA" is the month made. The number on the tag is the transmission cooler size or type. It is an internal Harrison radiator number.
The "ZL" rad code tag is not a Oldsmobile rad tag for 1965-1972. It is a newer style rad because of its slant neck and closer together transmission lines. The rad code tag however is not how Harrison made tags from 1968-1972. The "FT" rad code tag is for 1965-67 330CI and AC vehicles.
Old Feb 13, 2017 | 04:21 PM
All I know is I need an FU radiator for mine.
Old Feb 13, 2017 | 04:29 PM
Old School Olds
Thanks for the info guys, it is very much appreciated.
Old Feb 13, 2017 | 04:30 PM
Old School Olds
Koda, all 3 of these are F.U.
Old Feb 13, 2017 | 05:53 PM
Roger that.
Old Feb 13, 2017 | 06:02 PM
Old School Olds
Is an FU for a 67 442?
Old Feb 13, 2017 | 07:03 PM
RocketDevo's Avatar
The "FU" rad tag code is for 400CI motors with AC. It would be correct for an AC 442 in 1967.
costpenn
Jul 5, 2016 03:08 AM
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
L69
May 19, 2013 11:01 AM
jensenracing77
Mar 14, 2013 06:12 AM
