3.5 V6 build
3.5 V6 build
Anybody building a 3.5 V6 "shortstar" I've got one and a 6 speed FWD stick haven't decided what to put it in yet. Got a cam grinder to re-grind my 4 cams, and adding a turbo set up. I've got to finish my 23 T build & 01 Bullitt Mustang restore before I start a new project.
There's a Fiero on Barn Finds just crying for that setup.
I assume the Shortstar uses the same bellhousing as the N*? If so, there's only one bolt on the bellhousing that needs to be moved to adapt a RWD trans with the 60 deg V6 bolt pattern. Drop that in the 23T.
