2 screws missing from carb
ok so i have attached 2 pics of these screws that are missing from the carb and are causing a significant amount of fuel to leak, i cant find them at the hardware store and today i might goto the engine rebuild shop and c if they have any left over, and if i cant find it there, does any 1 have any extra laying around?
Remove the carb from the intake. The heads of the screws are on the underside of the throttle body. To be honest, I'm having a hard time understanding how these two screws are causing a fuel leak. The float bowl is totally contained in the center casting. Only the idle circuits pass into the throttle body and in that case, fuel only flows when there's vacuum. Since the pressure in those idle circuits is below atmospheric, air would leak IN if there were a leak; fuel would not come out.
I suspect your leak is coming from somewhere else. You might want to take a look at this:
http://www.oldcarmanualproject.com/m...nual/index.htm
andyman
Jul 25, 2012 03:09 PM
