2 bolt valve cover seals?
Old Sep 25, 2014 | 09:17 AM
stratoblues's Avatar
I just put my heads on after a valve job and found the holes in the seals for the bolts that hold on the valve cover were larger than the old seals. the old seals were snug to the bolt the new ones slide off the bolts. I was thinking of putting some gasket sealer ton them to hold them in place any ideas?
thanks
Gerry
Old Sep 25, 2014 | 09:44 AM
Octania's Avatar
Gasket sealer to hold gaskets in place?
Sounds like an Old Racer's Trick to me. Why not?
Old Sep 25, 2014 | 10:22 AM
The holes being slightly larger should not make a difference. Sealer is not required but can't hurt.
Old Sep 25, 2014 | 12:11 PM
Originally Posted by stratoblues
any ideas?
Yeah. It's likely that the old seals have been compressed after being under compression for all these decades, which caused the hole to tighten up. I've had this same problem on a Honda motor, where the old seal that goes on the valve cover stud is much tighter than the new one. Once you install everything and tighten the bolts, it will be fine.
Old Sep 25, 2014 | 01:52 PM
Im a bit confused. The seals are inside the valve cover to keep oil from blowing out the 2 holes. If the seals slide down the bolt to the threads how will the hole be sealed in the valve cover?
Old Sep 25, 2014 | 01:58 PM
No, sorry, I'm the one who's confused. I was under the impression that you were talking about seals that went on from the top and were compressed by the nuts. Is there supposed to be some sort of flanged washer on the underside that the seal compresses against? I've seen that arrangement on other engines.
Old Sep 25, 2014 | 02:05 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The seals go on the bolt and actually go between the head of the bolt and the outside of the valve cover. At least that is the way my 54 is. I can't imagine anyway you could seal them from the inside.
Old Sep 25, 2014 | 02:41 PM
My mistake the seals go on the outside of the valve cover.under a flanged piece of metal that acts as a washer that the bolt goes through. thanks to all
Legos
Drivetrain/Differentials
Feb 19, 2015 05:43 PM
monzaz
Sep 11, 2012 08:27 PM
jpc647
Sep 10, 2012 06:54 PM
Half Baked
Jan 10, 2008 08:43 PM
smogger
Aug 3, 2004 10:31 PM
