2-1/2 inch Pypes exhaust users - issues?
Old Jun 10, 2018 | 08:34 PM
83hurstguy's Avatar
Have any of you had issues with the exhaust manifold downpipes on the 2.5" kit? If so, how did you fix it?
The passenger side fits perfect. The driver's side is a nightmare... it hits the control arm mount, hits the trans crossmember (misses the arch), and due to the fact it hits the frame, it doesn't seal right on the exhaust manifold.
Some pictures are attached... I heated the pipe up with my torch and bashed the pipe in to clear the frame, but it's still not enough.
Of course, the Homecoming show is in 5 days... I'm going to have an aneurysm trying to get this $%(*& car there...
Old Jun 10, 2018 | 08:44 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
One other on Summit had the same issue. There is a thread on the G body site, quality control seems to be an issue.
Old Jun 12, 2018 | 07:22 AM
83hurstguy's Avatar
Thanks. Pypes was responsive and offered a new downpipe, but they won't have any in stock until July 23.
Other than Ram Air Restoration, it appears that nobody else makes mandrel bent 2.5" downpipes anymore (flowmaster discontinued, no dynomax or magnaflow). I called Ram Air Restoration yesterday and ordered a set, should be here tomorrow. Nice people, here's a link, though the picture isn't likely accurate:
https://www.ramairrestoration.com/ol...s-flanges.html
Old Jun 12, 2018 | 10:11 AM
If you live near a muffler shop, they can heat the pipe in the problem areas and mildly bend it to fit the places required to get to run where it needs to be.
Old Jun 14, 2018 | 05:55 AM
Let us know what the Ramair Restoration down pipes are like.
Old Jun 14, 2018 | 07:42 AM
2olds's Avatar
I have a old pypes system fits good on 70.
Old Jun 18, 2018 | 05:08 AM
Townie's Avatar
I had the same issue on the flange with my headers, I used heat and a huge pry bar to get it to seal. I think there should be a little more metal on the flared end of the pipe.
Old Jun 18, 2018 | 06:15 AM
83hurstguy's Avatar
We ended up heating it ourselves and bending it halfway where it needs to be, just to make it to homecoming. The ram air restoration pipes didn't arrive until the car was on the trailer to leave for the show. I probably won't get a chance to compare them and work with the new ones for a week or two, will post pics when I do.
Funkwagon455
May 14, 2015 06:44 PM
JR442
Feb 26, 2013 06:04 PM
1977 Delta 88 Flint
Feb 20, 2013 12:29 PM
jensenracing77
Mar 16, 2010 07:51 PM
njot33
Sep 17, 2008 08:13 AM
