1978 Delta 88 Engine Problems
If this post is in the wrong area I do apologize.
The other day we performed a tune up on my car. It has the 5.7 liter 350 CU V8. It ran fine for a week but then it refused to start. I got lucky one afternoon and got it strted but since then no luck. Here is what I have done:
Here is what we added to the engine in the tune up:
New Bosch Platinum plugs
New spark plug wires
Replaced valve cover gaskets
New cap and rotor
Here is what we have replaced since the car will not run:
New battery
New coil
New ignition module
New thermostat
And I am getting ready to install this:
http://www.autozone.com/autozone/cat...dName=Duralast
Any ideas why the car will not start? We have turned the distributor to try to mess with timing but she will not run. She acts like she wants to run and turns over nicely yet she will not start.
Anyone think I have broke valves or the timing chain needs replaced? Or will the part i am putting in do it?
New cap and rotor
New battery
New coil
New ignition module
New thermostat
If it ran fine for a week then I would not have moved the dist trying to fix it. I hope you have a mark on the original position. My guess is that it's electrical , possible as simple as a bad ground.
Well that is the first thing i would do is make sure that is good but I am thinking that it may be something in the ignition switch ground or reg. ground etc. it turns over ok until it kills the battery? I am not real familiar with the 78 350 Olds so hang in there and some other guys will help out too. you could also post a thread in the tech sections under general or electrical questions and someone will help you.
Yes we pulled the hose from the fuel pump to the carb to check for fuel. She is getting plenty of fuel. We also pulled number one and two spark plugs. She is getting spark. The spark is redish-white though.
Going the other way, you pulled off the pump-to-carb line, but have you actually taken off the air cleaner and looked inside the carb to see if fuel is getting in there? Does fuel squirt out of the little jets when you pump the accelerator? Maybe the fuel filter is clogged. (I don't know where the fuel filter is on your car. On mine, it is on the carb, and the pump-to-carb line connects to it.)
If the fuel is OK, do you have compression? It might be a dumb question, but is there a possibility of a blown head gasket? You should get a compression tester and make sure you've got good compression in all cylinders.
Right now it will have to sit. As soon as I get some money I'll check out the compression. I haven't checked the jets in the carb. I don't know what to look for. It makes no sense that I can drive it for a week then start it up on a cold Sunday morning and it dies and will not run anymore.
Check you spark first. Take one of the plug wire of of a spark plug and stick a philips head screw driver in the socket and hold it abour a 1/4" away from the intake maniflold in a safe location. Have someone crank over the engine and you should see spark jump the gap. If you don't see a spark then check and make sure your getting power to your coil primary. Let us know what you find out. could be a bad coil, even new coils go bad
We have already done just that. On more than one cylinder. We get spark. It just isn't the normal color. Instead of a blueish-white spark we are getting a redish-white spark.
I'm almost to tears with this. Thinking about just selling the car to the junkyard.
I haven't actually looked but I know after cranking the engine to start for a few minutes you can smell a very strong smell of gas as if it's flooding. I will have to look to see if the jets are working. I really hope I don't need to take the carb apart.
Don't install the ignition switch you put in your first post. You need to go about the troubleshooting procedure logically.
I suggest you remove the HEI module from your distributor and take it to the auto parts store to get checked. These will often go out without notice and there isn't any way you can repair it except for replacing it.
BTW, the squirt of fuel you see below the choke plate into the venturi is from the accelorator pump, not the jets. With the carburetor assembled you can't see the primary or secondary jets.
If you are talking about this:
We have already replaced it with a brand new one. Were you talking about some other part?
That is what I was talking about. If you've already replaced it and you know for sure it is good then I suggest you make sure you have compression and fuel.
Checking for fuel should be easy. Just remove the fuel line to the carburetor and crank the engine over and let the fuel flow into a coffee can. It should flow out pretty quickly. After a few moments you should have about 1/4 inch of fuel in the bottom of the coffee can. I know this is arbitrary but you will be able to tell if you aren't getting fuel to the carburetor.
To check compression just use a compression tester as the others mentioned.
Did you get the new wires hooked up in the right order? It is different than chevy engines I believe. Try putting the old ones back on to see if you got some bad new ones (Happened to me before).
Since you had added a new coil and ignition module, it might be good to retry the originals.
I suspect ignition - a redish white spark is not healthy. Weak sparks will not even occure under compression. A blue spark is healthy!
My 78 Ford with the Duraspark II system will shoot a blue spark from the coil to the fender - over one inch with a nice audible 'snap'! The HEI on your Olds should do the same or better.
In the process of trying to start it, you probably (accidentally) flooded it also.
Since the car was running shortly before you started all this, I doubt you have compression issues (unless an unusual catastrophic event happened).
Still trying to figure out why you have a reddish-white spark unless the gap is not right. It could also be a possability of flooding problem. I would take out the plugs and make sure the gap is right on all of them and I would remove the air cleaner then leave it for a couple of days , gas will evaporate.
Put the plugs back in and try to start again. push the pedal to the floor and turn the key , see if it tries to catch , if so let off the pedal and with luck she will fire up. if not it may be a compression issue. the only way to know that is to do a compression check on the cylinders.
Sounds like the timing chain jumped a tooth . Is it a high mile engine? If it turns over faster than normal and almost starts but will not catch, it has the symtoms of a bad gear.Check your timing again....Tedd
plastic gear ...
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
pull a plug, put finger in hole , when air pushes your finger out of hole follow that plug wire to the distributor and the rotor should point to that terminal ...
It's not a plastic gear. All the timing gears are metal.
Be that as it may the car is running now. All it took was getting rid of the Bosch Platinum plugs I had in there and putting in some AC Delco plugs. Runs just fine. Thanks to everyone that helped.
Glad you got it up and running!
The problem with the Bosch plugs were that the electrode is very small and once covered in any kind of contaminant that will not fire. The stock plugs have a way bigger electrode.
I still have other issues. I need to flush the radiator soon. I also need to figure out why cylinder one and two have bad compression at low RPM. They work fine at high RPM.
#33
http://www.hemmings.com/mus/stories/...feature14.html
"About the only weak link in these engines is the timing gear and chain," Duden said. "They came from the factory with the plastic coating and when we replace them we always use steel gears. The other problem is, the saddle that ties two rocker arms together is aluminum and it gets weak and breaks."
I am a fan of "Factory" parts like plugs ...
#36
X2 on this one , the only way to be sure of compression is to use a guage. it seems strange that a cylinder would have low compression at idle and not at higher RPM. But I am no expert so it would be nice if a couple would chime in on this one.
#40
Could have told you from experience Bosch plugs aren't worth a hoot in an Oldsmobile engine but I had missed this thread until today.
Any more I'm starting to have my doubts about newer production ACD too, since I put new R46SZ plugs in the wagon and it now gets worse gas mileage and a rougher idle. The ones I took out with 45k miles on them started and ran fine, and delivered around 16 mpg, but I figured they were close to the end of their service life. I'm down to 14 now
![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
BTW I despise ethanol fuel. It's not the savior the guvmint would have you believe it is, but the corn lobby is very powerful in Washten DC.
Do you have any lifter or valvetrain noise at idle? If a lifter isn't pumping up at idle oil pressure, that can cause the same low compression symptom as a weak cylinder. Once oil pressure gets normal, it will function fine.
