1972 Cutlass Supreme
Hello,
I need to replace the aga 30 fuse for the A/C fan on HI. The manual says it is located near the firewall but I don't see it. Can somebody help me pinpoint exactly where it is located please ??
Like Fred said, coming off the horn relay which is located on the driver side fender, there is a black rubber fuse holder that holds the very short 30 amp fuse. Most of the time I've found the rubber parts have fused together & you ruin the fuse getting the two halves apart. Maybe use some wd 40 to try to loosen it up?
One end is connected to the stud on the bottom of the horn relay, I "think" the other end goes to the high speed blower relay located behind the brake booster, assuming you have power brakes of course. Going off of memory, your wiring may vary
olds70supreme
August 1st, 2011 05:22 PM
mumpspro
September 24th, 2006 11:03 AM
