1972 Cutlass Supreme
Old May 24, 2015 | 04:11 AM
Apollo's Avatar
Hello,
I need to replace the aga 30 fuse for the A/C fan on HI. The manual says it is located near the firewall but I don't see it. Can somebody help me pinpoint exactly where it is located please ??
Old May 24, 2015 | 04:18 AM
442Fred's Avatar
It is an inline fuse coming from the horn relay to a relay located behind the power booster on the firewall. I believe it is a black wire with a red or orange stripe probably 10ga wire
Old May 24, 2015 | 06:27 AM
oldspackrat's Avatar
Like Fred said, coming off the horn relay which is located on the driver side fender, there is a black rubber fuse holder that holds the very short 30 amp fuse. Most of the time I've found the rubber parts have fused together & you ruin the fuse getting the two halves apart. Maybe use some wd 40 to try to loosen it up?
Old May 24, 2015 | 07:57 AM
Sully69's Avatar
Where does that wire plug into?
Old May 24, 2015 | 08:04 AM
One end is connected to the stud on the bottom of the horn relay, I "think" the other end goes to the high speed blower relay located behind the brake booster, assuming you have power brakes of course. Going off of memory, your wiring may vary
travisbeamon
Apr 6, 2013 09:37 AM
Oldssupreme
Jan 14, 2013 10:08 AM
olds70supreme
Aug 1, 2011 05:22 PM
Cutlass72Supreme
Dec 13, 2006 03:14 PM
mumpspro
Sep 24, 2006 11:03 AM
