1972 Cutlass Supreme 350 CI 4BBL
Old Dec 8, 2018 | 08:09 AM
Apollo's Avatar
Hello Folks,
I have two oil stains on my garage floor. One under the engine, one under the transmission. My Q is, what gaskets or parts could be the source of these leaks? Could somebody summarize the parts that could be responsible for the leaks, so I can figure where I'm going with repair costs. I'm thinking oil pan and transmission filter ( even though I've had it changed 2 times at tire kingdom ) ....
Old Dec 8, 2018 | 09:50 AM
RetroRanger's Avatar
72 Olds CS
Summary of parts = engine and transmission
idk what tire kingdom is but I will guess most of their employees don't take as much pride in their work as you do in your car. I.e. They may not be the best place to bring it for repairs.
the engine may likely leak from several sources like the valve covers, intake, rear main seal and oil pan. If you clean the engine you may be able to then narrow down the source of the leak.
the trans could leak at the pan, the dipstick seal, or could be converter drain back that causes an overfull condition leading to leaking. Cleaning the trans and then inspecting may also give you some insight into the source of the leak.
if the leaks are just drips from being an old car as opposed to adding quarts of fluid a week I would just keep an old piece of cardboard under the car when parked this will prevent driveway/garage floor staining and save you plenty of aggravation.
Old Dec 8, 2018 | 10:18 AM
scrappie's Avatar
Much like Retro said, could be leaking from numerous places. Another common leak is front and rear seal on trans if its an automatic? Replacement of the front seal requires removal of trans. Clean floor underneath and place a big piece of heavy white poster board or paper. You will then be able to maybe see color of fluid: Oil=brown to black, Trans fluid=red, anti freeze=green, power steering fluid= starts fairly clear but ends dirty usually around steering box or pitman arm and hoses.
Old Dec 9, 2018 | 08:51 AM
Agree with the others. I can't remember a time in the past 30 years that I didn't have some type of drip on the car. Presently the trans leaks after having it rebuilt a couple years ago - one of the cooler line fittings seeps, but there has been a piece of cardboard under the car since forever to keep the garage floor clean.
Old Dec 9, 2018 | 11:12 AM
Your going to have to do some detective work to determine where the fluid is coming from. Anyplacewith a machined surface with fluid and a gasket to contain it is a potential leak. You probably have several small leaks, I don’t think your going to find old iron of any kind that doesn’t mark it’s territory. The most likely culprits are valve covers, oil pan, timing cover, rear main seal, the trans could be oil pan, pump gasket and/or the o-ring, speedo housing, speedo cable seal, etc. One way to find out exactly where the oil is coming from is to add just a little of the fluorescent dye used to find leaks in A/C systems, add a little to the engine and trans. Take it for a long test drive, the dye will be easy to see with a black light. The dye is available at most parts stores for a few bucks.
Old Dec 9, 2018 | 11:51 AM
bw1339's Avatar
Powerwash the suspect areas and then watch from where the leaks are coming from. If the whole area is wet in oil, it becomes very difficult to see where the fluid is coming from.
truckman5000
May 17, 2017 08:23 AM
jc1671
May 15, 2017 05:58 AM
truckman5000
Jul 16, 2016 07:20 PM
Macadoo
21
Oct 6, 2013 09:04 AM
DAN76
Mar 25, 2009 08:26 AM
