1972 442 won't start
I have a 72 442 with a Rocket 350. Was running great till 2 weeks ago when it stated sputtering when I accelerated and then backfired a couple times. Took it out over The Weeknd for a short drive, stopped turned it off and now it will not start at all. Turns over just fine, spaying gas into the carb when trying to start and the filter on the gas line is good.
Any help greatly appreciated.
Pat
Pat
We'd be able to provide you with more useful answers if you gave us more information about the car. The mind reading thing still isn't working. Is the car totally stock? Has it been modified at all? If so, exactly WHAT has been done to it? Induction? Ignition? Wiring? All of these can contribute to your starting problem.
It cranks.
It has fuel.
Now check for spark.
If it has spark, check the timing (a timing light will work when you crank the engine, so long as you have spark).
If it doesn't have spark, figure out why.
It has fuel.
