1972 442 won't start
Old Jul 13, 2022 | 06:34 PM
patkjohnson72's Avatar
I have a 72 442 with a Rocket 350. Was running great till 2 weeks ago when it stated sputtering when I accelerated and then backfired a couple times. Took it out over The Weeknd for a short drive, stopped turned it off and now it will not start at all. Turns over just fine, spaying gas into the carb when trying to start and the filter on the gas line is good.
Any help greatly appreciated.
Pat
Old Jul 13, 2022 | 06:59 PM
You need to check for spark. What distributor are you running?
Old Jul 13, 2022 | 07:04 PM
tnswt's Avatar
'70 4-Speed W Machine
Coil died?
Old Jul 13, 2022 | 07:21 PM
66SportCoupe's Avatar
Timing chain??????
Old Jul 13, 2022 | 09:30 PM
Thanks everyone I will troubleshoot all above this weekend.
Old Jul 14, 2022 | 05:57 AM
We'd be able to provide you with more useful answers if you gave us more information about the car. The mind reading thing still isn't working. Is the car totally stock? Has it been modified at all? If so, exactly WHAT has been done to it? Induction? Ignition? Wiring? All of these can contribute to your starting problem.
Old Jul 14, 2022 | 06:53 AM
fleming442's Avatar
Fuel, air, spark
Suck, bang, blow
Old Jul 14, 2022 | 02:39 PM
It is all stock. 1972 442 Rocket 350.
Old Jul 14, 2022 | 02:47 PM
My bet timing chain gave up
Old Jul 14, 2022 | 03:07 PM
If still running points, check dwell and timing. It could also be a bad condenser.
Old Jul 14, 2022 | 03:46 PM
It cranks.
It has fuel.
Now check for spark.
If it has spark, check the timing (a timing light will work when you crank the engine, so long as you have spark).
If it doesn't have spark, figure out why.
Old Jul 14, 2022 | 08:43 PM
Has the car sat? How old is the fuel? I would start there. Of course check the spark. I am curious how old the gas is. Carburetor's sitting for a long time with today's fuel creates issues.
Just my two cents.
Old Jul 14, 2022 | 08:47 PM
Thanks, I drive it every weekend and I gas it it once a month.
Old Jul 14, 2022 | 08:52 PM
And, you said it’s completely stock….which means it has contact points ignition correct?
Old Jul 16, 2022 | 06:05 PM
All, thanks for all the help, turns out to be a broken coil wire! Runs great now.
Old Jul 16, 2022 | 07:13 PM
Glad you found it.
72cutlassdog
May 6, 2022 07:49 PM
morello72442
Jun 2, 2021 05:01 AM
chucky617
Jul 2, 2019 02:50 PM
Cutlassnovice
Apr 24, 2012 09:26 PM
godson
Dec 30, 2008 08:58 PM
