1971 w27 442. W27 in ‘71?
Old Nov 14, 2019 | 10:35 AM
vCode442's Avatar
Vincit qui se vincit
Not many of these around - a 1971 442 documented to have left the factory with a W 27 rear. Didn’t know you could still order the aluminum carrier in 71.
Also despite the incorrect hood striping for 71 the dual snorkel air cleaner /four-speed is sweet.
1971 Oldsmobile 442 W-27 Hardtop Coupe
https://www.hemmings.com/classifieds...2/2341963.html[img]blob:https://classicoldsmobile.com/11fb200b-c0d5-437b-8996-8b51ba725a13
Old Nov 14, 2019 | 11:09 AM
In 1971, RPO W27 was the cover only, for $26.33. It was not the whole aluminum center section. And that cover came on a ten bolt corporate axle, not a Type O. Once again, Hemmings gets the facts wrong. This is why I dropped their Musclecars magazine.
Old Nov 14, 2019 | 11:40 AM
rob1960's Avatar
The guy is a little optimistic. The W27 "cover" was available as an production line option or over the parts counter in '71. It's just an aluminum cover on the standard rear end. It's cool but nothing special. Yes I see it on the build sheet,so it definitely left the factory with the cover, but the edge of the sheet is missing. You can clearly see " W27 alum diff" but it's missing the word "cover". That is not a W27 rear in that car,the center section is iron. W27s came with the type "O" (12 bolt cover/10 bolt ring gear) rear end in 1970 only. That car has the 10 bolt rear that became standard in '71. Someone recently had a real W27 for sale for something like 10 grand......Ouch!!!!!
Old Nov 14, 2019 | 12:49 PM
vCode442's Avatar
Thanks guys, I could see it wasn’t the full aluminum carrier, but interesting to see the W27 option listed.
Again CO is the place to go for olds info!
Old Nov 14, 2019 | 12:50 PM
The ad says the car has a 3.31 rear gear ratio. I am not familiar with that ratio in the Olds lineup.
Old Nov 14, 2019 | 05:17 PM
The standard axle in a 1971 442 with 4spd would have been a 3.42:1 ratio. The only other option was 3.23:1 (RPO G91) and I don't see that listed on the build sheet.
Old Nov 15, 2019 | 02:50 AM
hurst68olds's Avatar
box 11 on the build sheet "SS" is 3.23:1 anti-spin (the 3.23s would've been standard with the A/C)
Old Nov 15, 2019 | 05:38 AM
Your eyes are better than mine. Thanks for pointing that out.
Old Nov 15, 2019 | 08:08 AM
VikingBlue's Avatar
Looking at that option sheet...the 3.08 was standard for AT cars with AC. Was anti-spin G80 (posi rear) available on 3.08 and all other ratios ?
Old Nov 15, 2019 | 08:12 AM
The car in question is a four speed. And G80 was available with any ratio.
Old Nov 15, 2019 | 08:55 AM
VikingBlue's Avatar
Yes Joe...sorry I wasnt clear. I was asking about my own car....1971 AT car with AC and no anti-spin option. I was wondering what my car's ratio most likely was from the factory.
Old Nov 16, 2019 | 04:12 AM
rob1960's Avatar
Most likely it's got 2.56 gears, can you still read the code on the pass. axle tube??
Old Nov 16, 2019 | 11:37 PM
Diego's Avatar
Also has W37.
The "442 stripes were painted correctly" is a joke.
Will1971
Drivetrain/Differentials
Nov 2, 2019 10:07 PM
friesjh
Mar 6, 2019 07:39 AM
Mikeb23
Aug 11, 2017 06:13 AM
rand5204
Oct 17, 2015 03:54 PM
.Rocket.Man.
Aug 22, 2014 09:37 AM
