1971 Olds 350 Rebuild Suggestions
Old February 7th, 2012, 08:33 AM
dallasite21's Avatar
I have a 71' Olds 350 that I am about to have rebuilt. It is currently stock with the exception of a performer intake. I believe that stock it is about 260 HP. I would like to get it at least over 300 HP. What can I do in terms of upgrades to get the most HP and torque without spending alot of money?
Basically Im looking for a budget rebuild to just give me maybe the same power as the 68-70 350's... Any suggestions would be greatly appreciated.
dallasite21 is offline
Old February 7th, 2012, 09:47 AM
Where were you in '72?
boondocker's Avatar
I started with the same questions less than a year ago and ended up in "might as well" hell, in the end the best solution for me was to do it complete and do it right. Rebore, flat top pistons, cam w/springs, lifters, moly rings, valve guides, seals, rockers, push rods, check block, heads (magniflux), crank turned, a complete bearing kit (con rods, crank, cam), felpro gasket kit w/valley pan gasket, oil pump, water pump. I may have missed a few items, but in the end it cost me about $2K in parts and machining, I did all the work myself except for the machining...farming out the assembly I'm guessing would be around $1k. I'm not sure if this would be in your budget, but if your going to open up the motor you "might as well".
boondocker is offline
Old February 7th, 2012, 09:56 AM
What kind of performance were you able to get out of the engine horsepower wise?
Old February 7th, 2012, 10:38 AM
boondocker's Avatar
HP wise I'm not sure, it hasn't been on a dyno (yet). My butt dyno tells me that it's up around 300, the torque is amazing though...I'm now contemplating a posi to get all this new found power to the ground. The Comp cams calculator says 315hp/400 torque, but not an exact science.
Old February 7th, 2012, 11:00 AM
delete
droptopron's Avatar
You goals are pretty modest comparitively speaking. Some basic head work and a decent cam should get you there. Just make sure everything you get will work well together.
droptopron is offline
calioldsboy
September 21st, 2012 12:33 AM
Jefhay6814
September 9th, 2012 09:47 AM
deejai35
September 3rd, 2012 07:53 PM
Delmont 88 PA
August 2nd, 2012 05:46 PM
nuttkaze
May 19th, 2012 09:19 PM
Quick Reply: 1971 Olds 350 Rebuild Suggestions
