1971 442 convertible
Old Jul 11, 2012 | 06:08 AM
L&L Auto Restorations's Avatar
I gotta question. Are the sheet metal, doors, quarters, and fenders generic for all of the 1971 Cutlas models including the 442? I know the hood is different with the cowl but what about the doors and trunk lid specifically?
Old Jul 11, 2012 | 06:40 AM
Boiler_81's Avatar
The doors and fenders are the same for all two doors. The various models do have different trim. Rear quarters are different by body style (Cutlass and 442 convertible, Cutlass S and 442 hardtop share a 1/4, Cutlass Supreme is unique to that model). Trunk lids also vary. The convertible Cutlass and 442 share a trunk lid with the four door Cutlass. The 2-door Supreme is unique to that car. The Cutlass S and 442 share a trunk lid.
Sheet metal will interchange from 70-72. The front fenders for 70s and early 71s is slightly different from later 71s and 72. The early fenders do not have crimps along interior top for crash crumple. The early ones are more expensive as they were not available from GM as service parts since very early in the 70s and are not reproduced.
Last edited by Boiler_81; Jul 11, 2012 at 06:59 AM. Reason: Added trunk lid information
Old Jul 11, 2012 | 09:36 AM
lshlsh2's Avatar
71 cutlass convertible
All 71 convertibles use supreme rear quarters. Trunk lids inter change with 4-doors. Rest interchanges except you don't want to put post doors on a convertibles.
Larry
Old Jul 11, 2012 | 11:49 AM
Boiler_81's Avatar
The Supreme and the convertible have different part numbers for the 1/4 panels. However, I believe they are substantially the same with the exception of the the area at the top well of the convertible. If this is incorrect, I am sure someone will correct this if necessary.
Larry
Old Jul 11, 2012 | 01:00 PM
lshlsh2's Avatar
Everything I have read or seen about 71 convertibles, they all were built as supremes. Now there could be some differences thus different part numbers. I need new quarters and the repops seem to be the same for all conv. I do rememeber reading something about the rear wheelwells being different in a conv.?
Larry
Old Jul 11, 2012 | 04:58 PM
Boiler_81's Avatar
Some of the reproduction companies assume you are going to cut the 1/4 below the top well. Therefore you can use the Supreme 1/4 panel on a convertible. Original GM 1/4s are different between Supreme and convertibles. There are some companies which now list the convertible quarter separate from the Supreme with a different part number.
The convertible wheelhouse is slightly different than a Supreme but the Supreme can be modified to work on the convertible.
Larry
Chuckthizzle
May 26, 2015 07:40 PM
halfmoontrail
Mar 22, 2014 05:20 PM
halfmoontrail
Aug 31, 2013 09:05 PM
scrappie
Jul 22, 2009 01:41 PM
Topless72
Jan 28, 2008 08:42 PM
