1970 w30 4 speed in the window
Old Dec 11, 2016 | 11:23 AM
mobileW-30's Avatar
Hi I'm looking at 1970 442 W30 4 speed . In this condition what should the value be ? original parts on the car are 256 carb , 977 distributor ,37 amp alternator , W-intake , f heads , block with one piston & rod missing , 4 speed , 391 Rear axle .
Ben in storage 30 plus years ,last registered 1980 . Just looking for value on the car ? In this condition .
Old Dec 11, 2016 | 11:27 AM
mobileW-30's Avatar
More pictures
Old Dec 11, 2016 | 12:22 PM
jensenracing77's Avatar
Does it have the broadcast card or any documents to prove it is a W-30? Even if you know it is one, documentation has a big affect on value. From what I am seeing it has a very strong value in parts alone, If it has documentation the value will go up significantly. Is the engine and transmission original numbers?
This may be a California emissions car.
Old Dec 11, 2016 | 12:28 PM
marxjunk's Avatar
documentation can add 10k+ to a car like that...easy..
Old Dec 11, 2016 | 12:52 PM
mobileW-30's Avatar
Yes it has paperwork , original window sticker , bill of sale from dealer and it is a California car from Whittier CA.. engine & team's are original number's to the car .
Old Dec 11, 2016 | 01:04 PM
w30hurstolds's Avatar
w30 price
nice find i bought one a year ago and paid 35k it was a 4 speed with paper work all numbers match
Old Dec 11, 2016 | 01:11 PM
truckman5000's Avatar
W30
I paid 27k, in better condition. But an auto. Id say offer 18k? See were it goes
Old Dec 11, 2016 | 01:28 PM
Joffroi's Avatar
Runner
Nice find and nice color combo. Restored value is really up there so you can use that to gauge what its worth not (- cost of restoration). Either way, subscribing to this thread to see what happens. Always nice to read about how W30s are still tucked away ready to be brought back.
Old Dec 11, 2016 | 01:30 PM
Olds442redberet's Avatar
I'd be doing everything I could to get that car. It looks really nice.
Any rust issues?
Old Dec 11, 2016 | 01:47 PM
mobileW-30's Avatar
Rust ! Just the typical fender's Ben a So Cal car it's hole life . original color platinum silver and black stripes . Need more information on value .
Old Dec 11, 2016 | 04:57 PM
classicmuscle442's Avatar
Nice find, doc's are gold, second the offer around 18 but be willing to up offer as needed, could help your retirement.
Old Dec 11, 2016 | 06:06 PM
steverw's Avatar
Man where do you guys find these cars? I would love to stumble on to one.
Old Dec 11, 2016 | 06:25 PM
s i 442's Avatar
Oldsmobile enthusiast
Man do 4 speeds tear up a car!
I would be interested in the engine's vin numbers.
Old Dec 11, 2016 | 07:46 PM
72xw30's Avatar
W30 - numbers and docs - can't be beat!
Great find! Good Luck.
Cheers,
Sam
Old Dec 12, 2016 | 11:32 AM
droptopron's Avatar
delete
Check & double check everything the guy says to confirm it's #'s matching. See if you can get a hold of one of those cameras you can snake down into the block & look for damage. It may be my eyes but does it have an A/C dash in it?
Value I wouldn't start at $18K. I'd start lower & work your way up. Value depends on what you want to do with it?
Old Dec 12, 2016 | 12:53 PM
oldspackrat's Avatar
No AC.
Old Dec 12, 2016 | 06:57 PM
70Post's Avatar
That's the correct dashpad setup for a non-AC non-post coupe car. Used the same pad as an AC car but with different vents on each and a filler plate in the upper middle.
Post coupe cars got the "smoothie" pads. EDIT: I meant to say, as Scott mentions below....NON-AC post coupe cars. (Good catch Scott!...thanks)
Pad must have had something heavy sitting on top of the gauge area based on the amount of sagging there....that or you have some REAL MEAN sunshine out there
Old Dec 12, 2016 | 07:25 PM
Also post sedans with no A C got the smoothie pad.
Old Dec 14, 2016 | 03:26 PM
BlackGold's Avatar
mobileW-30,
Some of us would love to see and hear more about this seemingly unmolested car. If you are able, post more pictures -- including the documentation, VIN, Fisher Body cowl tag, etc. Thanks.
Old Dec 14, 2016 | 04:23 PM
WTHIRTY1's Avatar
Escape From The Ordinary
Sweet find!
Some guys have all the luck!
What color is that w-machine?
Old Dec 15, 2016 | 07:54 AM
kjr442's Avatar
Kjr442
Nice find, hope you get it.
Old Dec 15, 2016 | 10:15 PM
Stefano's Avatar
Nice find. Keep us posted.
Old Dec 16, 2016 | 02:28 AM
davebw31's Avatar
OK I think I know about this W30. Some ? to confirm
Is this car in Reno. NV?
If so I have seen this car in his garage and confirmed VIN, carb, block, trans, and rear end is numbers matching when I was there in Reno in 2011.
Old Dec 17, 2016 | 11:42 AM
Achcoastal's Avatar
this looks like a similar color: 1971 paint code 68 "sable brown"with gold stripes" on my 70 c/s w 30 replicar with many parts from a basket case w 30. good luck with the buy!
Old Dec 18, 2016 | 11:53 AM
mobileW-30's Avatar
Davebw31 yes the car in Reno . The one you looked at . The color on it now is first owner's highschool colors because the factory color is 14 14 and black stripes faded out from SO CAL sun and smog back in the day . The piston and rod went through pan when the second owner raced a turbo Porsche onto the 5 freeway . the second owner said he beet the Porsche but as you can see the results .
Old Dec 19, 2016 | 06:39 AM
davebw31's Avatar
He paid somewhere around $450 or $850 because of the front end damage. I know it was under $1,000.00!
70-442-W30
Sep 2, 2024 11:47 PM
Ap6954
Mar 26, 2016 07:36 PM
halfmoontrail
Jul 22, 2013 06:51 AM
L69
Mar 11, 2013 08:27 AM
Vader
Feb 21, 2012 06:29 AM
