1970 Cutlass S glove box liner
Old Feb 24, 2021 | 04:37 PM
wherlehy's Avatar
I am trying to install a new glove box liner in my '70 Supreme but the son of a gun will not fit through the opening. I have removed the lid and the lock latch and it is still is a son of a gun.
Do I have to remove all the air duct plumbing (it has original AC) under the dash to install?
Please help all you veteran Cutlass
lads.
Regards,
Bill
Old Feb 24, 2021 | 04:41 PM
66SportCoupe's Avatar
It gets installed from the rear under the dash.
Old Feb 24, 2021 | 04:42 PM
Yellowstatue's Avatar
Well some of us have discovered that A/C cars have smaller glove boxes than non A/C cars. Was scratching my head for a while wondering why.
Old Feb 24, 2021 | 04:44 PM
Oh and not to be an ***. Your car is a Cutlass S not a Supreme.
Old Feb 25, 2021 | 11:57 AM
Jungle Cat's Avatar
Just a suggestion. Try putting it in perpendicular to the dash then try and turn it. Try both opening of the box left and right. Thought I did it that way before.
Old Feb 25, 2021 | 12:22 PM
wherlehy's Avatar
Thank you for the suggestion - I tried putting it in perpendicular but it still won't go in. I believe it is due to the earlier comment that AC equipped models have a smaller glove box opening.
Old Feb 25, 2021 | 01:36 PM
Jungle Cat's Avatar
I did it on my friends Hurst Olds a few years ago but it’s fuzzy how we did it. I’m thinking we put the ducts in first through the opening? Not sure how we got them in if box was done first?
Old Feb 25, 2021 | 01:41 PM
wherlehy's Avatar
Thank you for for the clarification. I did not know the "S" was a mid-level option - I thought it stood for Supreme.
Old Feb 25, 2021 | 02:59 PM
RetroRanger's Avatar
72 Olds CS
the supreme is a notchback bodystyle opposed to your fastback style body, the 70-72 supremes look similar, as do 70-72 s models
Old Feb 25, 2021 | 03:10 PM
The opening isn't smaller it's the back of the glove box is closer to the front because of the duct work behind.
Old Feb 25, 2021 | 03:33 PM
wherlehy's Avatar
To update everyone - I got the glovebox in - I had to remove the ducting and go underneath - worked well. Now getting all those little screws fastened with the flimsy felt board... I had to take a brake before lost my patience...
Aug 18, 2020 08:00 PM
Rustbucket2
Jan 28, 2018 05:44 AM
stcsawdust
Aug 6, 2012 04:09 AM
yeahbuddy
Dec 12, 2011 07:22 AM
mmurphy77
Jan 28, 2011 11:10 AM
