1970 blower motor cage hub loose not grabbing the cage housing - fix?
1970 blower motor cage hub loose spins, not grabbing the cage
Anyone ever had a blower motor hub loose/spinning within the cage? Thought I would just add a weld, but the hub is cast/pot metal?. Any one fixed one these? Thanks
Update - Fixed it, used a vice and sockets to compress the hub flange on the back side, hope it holds up., works fine now.
