1970 8 track installation help
Old Jan 20, 2013 | 06:43 PM
Dave70Cutlass's Avatar
Do you anyone have instructions to install 8 track? I have a 70 that never had an 8 track installed. Primarily wondering how to get the top bolts that are mounted thru the dash. Any help would be appeciated. Dave
Old Jan 20, 2013 | 07:18 PM
pogo69's Avatar
morgan
The 8 track housing has a bracket on each side with a stud, it is attached from underneith with the studs coming up thru the holes and attached by 2 nuts...dont forget the ground cable
Old Jan 20, 2013 | 07:34 PM
The holes must be pretty big then because the unit must be flush to the dash and the other flat brackets must be screwed into dash. Pardon my confusion
WTony
Dec 5, 2022 02:42 PM
hueveaj
May 4, 2013 08:50 AM
fjross
Jan 21, 2013 04:24 AM
scott_442
Dec 21, 2008 11:09 AM
2 door cut
May 14, 2007 07:52 AM
