1969 Oldsmobile 442 Quadrajet Choke
Old April 21st, 2022 | 03:01 PM
Fisher442's Avatar
I have an original numbers QuadraJet Carburetor for the equipment I have No. 7029251 on the original intake with the original choked. I know the choke spring has lost it's oomph and not allowing the choke to open fully. Is there an electronic replacement available for replacing this? Thanks, Al
Old April 21st, 2022 | 03:10 PM
There is an electric choke available if this is your question? Remove manual choke, install electric choke. We have a preferred protocol for wiring the electric choke if you decide this is what you want.
https://cliffshighperformance.com/pr...tail-connector
Old April 21st, 2022 | 03:14 PM
69HO43's Avatar
Why not replace it?
There's a few on ebay NOS, but they're pretty spendy. The Parts Place has a repro that may work for $79. No experience with it, but IMO, it beats trying to modify what you have.
1969 Oldsmobile Cutlass/442/F85 CHOKE THERMOSTAT WITH ROD | Oldsmobile Cutlass/442/F85 Parts | CB1519T (thepartsplaceinc.com)
Old April 21st, 2022 | 03:16 PM
In case you elect to go w/ an electric choke.
Electric choke wiring
Old April 21st, 2022 | 07:43 PM
The choke in that link only works for the 1970-newer carbs with integral choke. 1969 uses a divorced choke.
Old April 21st, 2022 | 09:12 PM
tru-blue 442's Avatar
Old School Olds
I may have an original, I can check if you like.
Old April 21st, 2022 | 09:45 PM
Sugar Bear's Avatar
Isn't the "oomph" more to close the choke than open it? Is the crossover in the intake manifold getting hot?
Old April 22nd, 2022 | 04:17 AM
Joe, I either forgot or I didn't realize 1970+ carbs. Thanks.
Old April 22nd, 2022 | 05:39 AM
Fisher442's Avatar
- Yes Joe is correct it is a divorced chock so the electric type suggested won't work. I guess my question would be is there an electric replacement for the divorced type used on a 69?
- Yes, I would love to replace it and I'm aware an aftermarket is available for $79 but my experience it would most likely be junk!
- Tru Blue if you have a good working original I'm interested.
- Sugar Bear thats an interesting question about the cross over, never actually checked it. When the manifold heats the coil will expand but it is 52 years old and I'm sure its lost its oomph! I'm going to remove the coil and bench test it.
Thanks for the responses
Old April 22nd, 2022 | 06:12 AM
Old School Olds
I found an original, but 1st you may check to see which hole in the choke flange you are using. Some work better than the others.
If you decide you need this one, PM me.
Old April 22nd, 2022 | 06:56 AM
Fisher442's Avatar
Old April 22nd, 2022 | 08:23 AM
67OAI's Avatar
Old(s)GuysRule
Contact Ken at Everyday Performance, www.everyday-performance.com. They sell electric choke conversion kits for divorced choke quadrajets. On the website there is none listed for the Oldsmobile QJ but the Pontiac kit looks like it should work. The Pontiac and Olds divorced choke QJ are almost identical on the choke side.
ELECMAN
March 12th, 2024 12:45 PM
AlexLaumeyer
March 4th, 2022 03:13 PM
edzolz
May 20th, 2018 04:10 PM
oldolds88
February 5th, 2017 08:38 PM
justinj
November 5th, 2008 07:07 PM
