1969 cutlass s convertible
Just starting to put back together.
Some questions.
Putting in new frame bushings and there are 2 sizes. 8 are the same size and 2 are slightly smaller (hole size and thickness). Where do the 2 smaller ones go. I did not note this when I took apart.
I am putting a different power steering unit (doing the jeep conversion). The pitman arm and steering linkage are not lining up. Will the steering linkage move when I put body back on frame and engine as well?
Also does anyone have a good picture of how the brake line goes through the frame above differential.
Some questions.
