1968 questions- has a 70 455 4 speed...
Old Jun 14, 2025 | 01:21 PM
nooldsyet's Avatar
I am enjoying my new to me 68, and am formulating a list of things I need to fix over the summer. Some questions to help in my repairs..
1. This one is a priority!! Previous owner has a fuel line running from the fuel tank to a FOLGERS (coffee) can on the PS radiator support. I am assuming this is some type of return line, as it fills to 1/3 of the way. The car is a 68 442, with a 70 455 in it. I did see that the tank is new, and has the 69? style 2 vent lines going to the plastic vent. I assume this is correct for a 68?
2. I have to replace the fuel sending unit, as the fuel gauge is off by 1/4 of a tank. Should there be a return line from the fuel pump?
3. E brake cable routing. It should go UNDER the exhaust, correct? I know on Buicks it routes under...
4. There are aftermarket sending units to make the rally gauge cluster functional?
This fall/winter it will be get the gauges functional, new interior, fix the damn E brake cable rattle, disc brakes, figure out if there is a way of cutting the hood hinge base off of the 68 and have Willie at the hood hinge place do the same with a 69 hood hinge, fix the radio, box the rear control arms, and other small things.. The fuel issue needs to be fixed NOW....
Thank you
Old Jun 14, 2025 | 06:55 PM
2blu442's Avatar
Not all fuel pumps have the return line. I would suggest you check the 1968 fuel pump and if it doesn't have the return line install it instead of the 1970 pump. John
Old Jun 14, 2025 | 11:50 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
A/C cars have the fuel return line and matching tank.
Like John said get the pump for a car W/O A/C with no return. There is no 100% safe way to cap that return nipple off.
The E-brake cables should be above the exhaust, routed through the trans support cross-member, for a factory 68 442 TH400 OEM cross-member.
Troubleshoot the fuel gauge problem don't toss parts at it. Could be the gauge, the wiring/connections, grounds or the sender. The float rod might be bent hindering full travel.
I don't understand what you are doing with the 68 only hood hinges. Trying to make the 68 hood have more vertical lift like a 69?
Old Jun 15, 2025 | 08:05 AM
joes_olds's Avatar
If the trans was swapped to a THM 400, it's possible they didn't switch the e-brake cable when the moved the cross member back to fit the larger trans.
kevdz79
Oct 18, 2022 01:43 PM
jimjific
Jan 23, 2017 09:12 AM
dfire25
Jun 28, 2016 01:37 PM
Xlhowie
Aug 19, 2013 07:34 AM
Niko
Apr 24, 2013 06:33 PM
